Hey guys, I'm about to get parts for my first computer build. I'll be using it heavily on Photoshop and Video Editing. I plan on buying a Intel 4690k, but I don't really know what parts to go with it, do you guys have any suggestions? I already have a Radeon 7520 I pulled out of my Dell XPS 8700 to go with the build. So can you guys help me decide? I don't plan on going AMD for the CPU. Also, what cooler should I get?
https://linustechtips.com/topic/172189-need-help/
What is your budget/location?
https://linustechtips.com/topic/172189-need-help/#findComment-2288413
That video all not be useful for this thread parts wise.
A Radeon 7520 is so bad for this thing.
Although you're right, I don't really have the budget to get something like a 750 to... Mainly because I just got one for my other build. This computer is going straight to my dad
https://linustechtips.com/topic/172189-need-help/#findComment-2289630
Tried to put together a $800 rig for the purpose of video editing here, assuming you are set on an Intel CPU and already have your GPU. I couldn't quite squeeze an SSD into this build, and there is also no OS. If you can find the extra $80, I'd recommend a 120gb Samsung EVO 120gb to install your OS on. Hope this helps:
http://pcpartpicker.com/p/3d4xbv
You were a noob once too!
https://linustechtips.com/topic/172189-need-help/#findComment-2316370
