Cable For headphones
Solved by SirRoderick,
You could use a V-moda cable, they fit those jacks with no trouble http://v-moda.com/accessories/
This is for the audio only cable http://www.head-fi.org/content/type/61/id/767332/width/500/height/1000/flags/LL pretty sure the coiled one would fit as well in that case.
Issac Zachary ·
Posted in Troubleshooting2 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0
play_circle_filled
Latest From ShortCircuit:
