Basic questions about motherboards
Solved by Tazman192,
Not all motherboards have wifi - most gaming ones dont as manufacturers correctly assume gamers will use a wired connection. If yours doesn't have built in wifi you can, as you said, pick up a wifi adapter for less than £8.
You don't need a soundcard. There was a point a few years ago that you would need soundcards if you were an audiophile, but nowadays onboard sound is more than adequate for an average user. That money is better spent on a GPU or a processor. Those are what make the performance difference when doing whatever tasks you'll be doing.
FYI: Your motherboard does not have wifi built in, but if that is an issue, the problem is easily rectified. This will do the job
