So a while ago I got a EVGA GTX 770 4gb ACX cooled gpu, and then I got the second one so I ran them in sli with a fair amount of space in between the two cards (like 5"). However, the mobo I used recently died, and so I had to buy a new one. However, because of the way the pcie slots are wired, the two cards are much closer together (running it on the first two pcie slots).
So my question is how badly will the top card heat up running like this? Should I be really concerned?
(the motherboard is a Z97 FTW also from EVGA)
https://linustechtips.com/topic/170345-acx-cooling-sli-setup/
The best thing you can do is monitor the temperatures.
https://linustechtips.com/topic/170345-acx-cooling-sli-setup/#findComment-2264121
As a generell rule of thumb I´d always recommend the first card (only nVidia) to be in reference design when using an aircooled multi GPU solution.
Sure thing you probably won´t buy another graphics card, so I´d do what MegaDave91 said, just monitor your temp curve and maybe indiviually adjust the fan levels to the best setup regarding the overall air flow and size of your case.
GreetZ Naj
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/170345-acx-cooling-sli-setup/#findComment-2264285
I had this thought- if I install a backplate on the bottom card, would that improve anything?
It might smooth out the airflow a bit but, it probably wouldn't do to much. However, won't make that much of a difference. The most important thing is getting the hot air out. since I assume you're using the same case, you should be fine. Have fun with the SLI setup!
CPU: Intel i7 4770k w/Noctua NH-D15, Motherboard: Gigabyte Z97 Ultra Durable, RAM: Patriot 8Gb 1600Mhz (2x4Gb), GPU: MSI R9 390x Gaming,
SSD: Samsung 840 EVO 1Tb, HDD: Caviar Black 1Tb, Seagate 4Tb Hybrid, Case: Fractal Design Define R4, PSU: Antec Earthwatts 750w
Phone: LG G2 32Gb Black (Verizon) Laptop: Fujitsu Lifebook E754 w/ 1TB Samsung 840 Evo SSD Vehicle: 2012 Nissan Xterra named Rocky
https://linustechtips.com/topic/170345-acx-cooling-sli-setup/#findComment-2276383
After benchmarking the cards I saw that the top card under load was reaching almost 100 C. If I used a fan to force cool air between the cards, that should help right?
An exhaust would probably be better as it would pull the hot air away as well as draw fresh (or fresher) air in due to a low pressure zone.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/170345-acx-cooling-sli-setup/#findComment-2276690
