Hi over the weekend i have done hours of research and have narrowed down my purchases to these 2 laptops. i would like a second opinion before I purchases one. Just curios what one has more power for gaming and good cooling/build quality.
lenovo y 50 $1,149.00
Processor:4th Generation Intel Core i7-4710HQ Processor (2.50GHz 1600MHz 6MB)
Operating System:Windows 8.1 64
Graphics:NVIDIA GeForce GTX 860M 2GB
Memory:8.0GB PC3-12800 DDR3L SDRAM 1600 MHz
Display:15.6" FHD LED AntiGlare Backlight (1920x1080)
Hard Drive:Hybrid 500GB 5400 RPM+8GB SSHD
Battery:4 Cell 54 Watt Hour Lithium-Ion
Bluetooth:Bluetooth Version 4.0 Warranty:One year
Optical Drive:None
Network Card:Intel® Dual Band Wireless-AC 3160
msi gx 60 $1,199.99
CPU  A10 5750
OS Windows 8.1
Chipset Bolton M3
Memory DDR3L up to 1600MHz, 2 slots, support up to 16GB (has 8gb)
LCD Size 15.6" Full HD (1920x1080), Anti-glare
Graphics AMD Radeon R9 M290X Graphics VRAM GDDR5 2GB
HDD (GB) Up to 128GB SATA + 1TB SATA 7200rpm
Optical Drive BD Combo/DVD Super Multi
Audio Audio Boost, 2x2W/1
Speakers Webcam HD type (30fps@720p)
Card Reader SD(XC/HC)
LAN Killer Gaming Networking Wireless LAN 802.11 b/g/n
Bluetooth Bluetooth 4.0
D-Sub (VGA) 1
HDMI 1(v1.4)
USB 2.0 port 1
USB 3.0 port 3
Mic-in/Headphone-out 1/1
Line-in 1
Express Card N/A
Keyboard 103 keys
AC Adapter 180W
Battery 9-Cell Li-Ion(7800mAH)
Dimension 395 x 267 x 55mm
Weight (KG) 3.5Kg (w/ Battery)
https://linustechtips.com/topic/170337-need-help-with-laptop-decision/
Processor:4th Generation Intel Core i7-4710HQ Processor (2.50GHz 1600MHz 6MB) Operating System:Windows 8.1 64 Graphics:NVIDIA GeForce GTX 860M 2GB Memory:8.0GB PC3-12800 DDR3L SDRAM 1600 MHz Display:15.6" FHD LED AntiGlare Backlight (1920x1080) Hard Drive:Hybrid 500GB 5400 RPM+8GB SSHD Battery:4 Cell 54 Watt Hour Lithium-Ion Bluetooth:Bluetooth Version 4.0 Warranty:One year Optical Drive:None
msi gx 60 $1,199.99
CPU AMD Quad Core A10-Series Processor OS Windows 8.1 Chipset Bolton M3 Memory DDR3L up to 1600MHz, 2 slots, support up to 16GB LCD Size 15.6" Full HD (1920x1080), Anti-glare Graphics AMD Radeon R9 M290X Graphics VRAM GDDR5 2GB HDD (GB) Up to 128GB SATA + 1TB SATA 7200rpm Optical Drive BD Combo/DVD Super Multi Audio Audio Boost, 2x2W/1 Speakers Webcam HD type (30fps@720p) Card Reader SD(XC/HC) LAN Killer Gaming Networking Wireless LAN 802.11 b/g/n Bluetooth Bluetooth 4.0 D-Sub (VGA) 1 HDMI 1(v1.4) USB 2.0 port 1 USB 3.0 port 3 Mic-in/Headphone-out 1/1 Line-in 1 Express Card N/A Keyboard 103 keys AC Adapter 180W Battery 9-Cell Li-Ion(7800mAH) Dimension 395 x 267 x 55mm Weight (KG) 3.5Kg (w/ Battery)
might want to add what games/apps youll be playing and that kinda thing
msi gx 60 $1,199.99
I'd go with the lenovo. although the m290x is better, the a10 is a piece of crap in comparison to an i7.
Do yourself a favor, and get an ssd version of the lenovo.
On a side note....since when does AMD do mobile graphics...I can't even remember the last time I saw a laptop with an AMD gpu.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
AMD has been doing mobile graphics for a long time, all the way back to DX7 days. They just are not generally used over nvidia for whatever reason (probably power consumption?).
As for the OP, I would also suggest the Lenovo. SSD or not, that is your (op) choice.
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
i play alot of blizzard games and some games like dark souls 2 ect
Lenovo for sure, most blizzard games such as WoW are extremely CPU bound and the i7 will have a huge advantage over the apu
Me: Yeah I just really can't get my H220 working again, I've tried everything that was suggested in the forum.
Brian (Swiftech Support): Hmm, have you tried slapping it?
OK COOL THANKS FOR ALL THE HELP GUYS
I have another question how does price match from ncix work when checking out online here it is on ncix website
http://www.ncix.com/detail/lenovo-ideapad-laptop-y50-i7-4700hq-9e-98199.htm
here is the one on lenovo website
http://shop.lenovo.com/ca/en/laptops/lenovo/y-series/y50/?sb=:000001CA:000056A2:
they say they are the same but the hdd is bigger on the one from ncix and the cpu is a 4700 instead of 4710 will that matter if i price match threw ncix?
