how to activate COD4 product key
Solved by Askew,
maybe i havent elaborated myslef quite well. i dont have a CD, nor can i redeem the code on steam, all i have is a product key. is there any way to activate it?
Sounds like a retail key that came with the game DVD.
If that's what I had and I wanted to just play multiplayer then I would torrent the ISO and don't crack it just install and put your CD key in, the multiplayer part of the game doesn't need a CD it just needs a valid CD key to play online.
