With haswell refresh and devils canyon, I'm going to swap over and upgrade my system.
I'm thinking of going with an i5. Maybe a 4590 or 4690. Have trouble deciding if the 4690 is worth the extra price.
There's also a small part of me that wants the 4690k, however with my current AMD CPU, I never actually overclocked it, and may never will with the devils canyon chip, so I may or may not get it.
tl;dr which is better from price/performance standpoint: 4590/4690. 4690k worth getting even though I might not overclock?
https://linustechtips.com/topic/169570-switching-over-to-intel-need-help/
4690 would be a nice price/performance standpoint
may as well get the 4690k over the 4690, it is only £20 more plus even if you don't overclock straight away atleast you have the option too.
Or even the 4670k and get it cheaper as there is basically no difference between the two unlocked i5's
CPU: i7 8700k Motherboard: MSI Z370 Krait Gaming RAM: 4x 8GB Corsair Vengeance Pro (2 white, 2 black) GPU: MSI RTX 2070 Armor Case: Corsair Crystal 570x White HDD: 2x 2TB Seagate Barracuda 7200rpm Sata 3 SSD: 240GB Corsair Force 3 + 500GB Samsung 970 Evo Cooling: Corsair Hydro Series™ H150i PSU: Corsair RM750i OS: Windows 10 Pro 64-Bit
Mouse: Logitech G600 Keyboard: Corsair K95 RGB Cherry MX Brown Monitor: Samsung S24C570L 1080p 23.6" + AOC AGON 240Hz 1080p Sound: HyperX Cloud Headset Black/Red + Logitech Z213 Speakers 2.1
if you already have a decent aftermarket cooler you could go 4690k and, as you can also oc devilscanyon on non-z chipsets, get a cheaper h97 mb.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
If you are not getting an unlocked processor get the 4690
