can you install a diffrent aircooler from a gpu ? like a dead MSI TF4 cooler on an asus?
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/16884-best-gpu-air-cooler/#findComment-193339
in the old days, those were helpful for temp control on air-cooling, but now with
the newer tech, the cards are not that hot like the 480/6970 GPU.
so the aftermarket is just kinda there and adaptable, but no one really shouting
best thing since sliced bread over an aftermarket GPU cooler on newer cards.
different pcb packages, GPU core offerings, and VRM make the aftermarket
fan kits hard to use.
airdeano
https://linustechtips.com/topic/16884-best-gpu-air-cooler/#findComment-193381
arctic and gelid have had decent reviews
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/16884-best-gpu-air-cooler/#findComment-193385
Makes Gelid VGA coolers fro 660 ti?
no but i could of swore they did i messed up it was 560 ti sorry. arctic might though
https://linustechtips.com/topic/16884-best-gpu-air-cooler/#findComment-198999
