What is the best display for Fps games ,some say 2ms or less say is best while others say 5ms response time is fine ,and actually has no affect on input lag.  What I'm asking is what to look for in a display if I play COD and bf4 and want the biggest advantage against my emeny?
https://linustechtips.com/topic/168492-display-for-fps-comp/
CRT
1ms is best with current monitors. My monitor has 6ms and I do just fine in games.
https://linustechtips.com/topic/168492-display-for-fps-comp/#findComment-2241425
I also hear that the response time only helps with motion blur
Why would you want motion blur in an FPS? Do you mean ghosting? Then yes.
Ghosting is annoying, but there's no good way to measure. The "GTG" spec of a monitor is the equivalence of me telling you I have an 8 inch wiener and I know because I measured it using a cheese stick. There's no standardized way to measure it, it's more or less a useless spec. Instead look for reviews that examine or mention the ghosting of a certain panel.
Error: 410
https://linustechtips.com/topic/168492-display-for-fps-comp/#findComment-2241458
Should I get a BenQ I alot of the pro cod players like benq
No, you should get the best monitor that has what you want for the price. Be it BenQ, Asus, or whoever else
Wait a bit more, there are a few more people that know about monitors (I personally don't care much for, hence know little)
@GoodBytes or one of the other display regulars might be able to point you to a decent website for panel reviews.
Error: 410
https://linustechtips.com/topic/168492-display-for-fps-comp/#findComment-2241506
Just read that sentence again, and tell me you're serious.
"Since the Internet is almost diametrically opposed to the notion of Quality Control, in recent years it's been a lot easier to just assume everything's s**t until it can prove itself otherwise".  Ben "Yahtzee" Croshaw (2008)
https://linustechtips.com/topic/168492-display-for-fps-comp/#findComment-2241508
