I am planning to build my first desktop and my budget will be around $1300. I need help with a build.
I would like to have an i5 processor ( my friend was saying this one http://www.newegg.com/Product/Product.aspx?Item=N82E16819115233 )
I would also like to have a 770 graphics card(not sure from what company but one that performs and looks nice)
I would also like to have to NZXT H440, it just looks really nice but I'm not sure whether to get it water cooled with like the H100i or H105, or to just keep it air cooled.
With this in mind I will still need a new keyboard and monitor along with windows operation system ( preferably windows 7 unless convinced otherwise)
https://linustechtips.com/topic/167291-i-need-help-with-a-build/
get an i5 4690k
as far as cpu cooling, just go for whatever suits you.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2226035
Hello and welcome to the fourm. Enjoy your stay.
PCPartPicker part list: http://pcpartpicker.com/p/qVcNgs
Price breakdown by merchant: http://pcpartpicker.com/p/qVcNgs/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($239.99 @ Amazon)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($157.99 @ Newegg)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($134.99 @ Amazon)
Storage: Western Digital WD Green 2TB 3.5" 5400RPM Internal Hard Drive  ($76.49 @ Amazon)
Video Card: PNY GeForce GTX 770 2GB Video Card  ($289.99 @ Newegg)
Case: NZXT H440 (Red/Black) ATX Mid Tower Case  ($119.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ Newegg)
Other: Be quiet! Dark Rock 3  once it's back to it's normal price of 59.99 ($59.99)
Total: $1204.41
Generated by PCPartPicker 2014-06-16 16:39 EDT-0400
EDIT: Oh? It's 1300?
Then go for this
PCPartPicker part list: http://pcpartpicker.com/p/hMbcRB
Price breakdown by merchant: http://pcpartpicker.com/p/hMbcRB/by_merchant/
CPU Cooler: be quiet! Dark Rock 3 113.8 CFM Fluid Dynamic Bearing CPU Cooler  ($79.99 @ NCIX US)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($134.99 @ Best Buy)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card  ($351.30 @ Newegg)
Total: $1285.72
Generated by PCPartPicker 2014-06-16 16:48 EDT-0400
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2226063
For watercooling do you want performance or software enhancements?
If peformance, go with the H110
If sowftware, go with H100i
If a litle bit of both, go with the h105.
As for the rest of the build ill see what i can make over at Pc Part picker, be back in a sec
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2226076
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($233.97 @ OutletPC)
CPU Cooler: Swiftech H220 55.0 CFM Liquid CPU Cooler  ($128.64 @ NCIX US)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard  ($125.99 @ Amazon)
Memory: A-Data XPG V2 8GB (2 x 4GB) DDR3-1600 Memory  ($69.99 @ Newegg)
Storage: Crucial M500 120GB 2.5" Solid State Drive  ($70.26 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: MSI Radeon R9 290 4GB TWIN FROZR Video Card  ($418.98 @ Newegg)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($119.99 @ Newegg)
Power Supply: SeaSonic G-750 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($89.99 @ Newegg)
Total: $1296.80
Generated by PCPartPicker 2014-06-16 16:44 EDT-0400
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2226092
Total: $1296.80
Woah the colours in the build are messed up tho.
I mean a black blue motherboard, golden ram, a black and white case and a red and black GPU?
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2226122
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($239.99 @ Newegg)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($90.98 @ Newegg)
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard  ($137.99 @ Newegg)
Video Card: EVGA GeForce GTX 770 2GB Superclocked ACX Video Card  ($301.98 @ Newegg)
Total: $1160.16
Generated by PCPartPicker 2014-06-16 16:52 EDT-0400
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2226142
yeah well, rught, but i didn't really care bout the way it looked Bro
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2226147
at least you got black every where
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2226152
CPU Cooler: Corsair H110 94.0 CFM Liquid CPU Cooler  ($108.58 @ Amazon)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($64.99 @ Micro Center)
Total: $1241.49
Generated by PCPartPicker 2014-06-16 17:20 EDT-0400
Edited by mcmad358
Current
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2226287
Total: $1241.49
Thank you, I think that this one will be my best bet! it has a nice color scheme and it is affordable. Thank you all for your suggestions, it helped me a lot
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2226486
No problem! I love helping with builds! Hope you enjoy it! It should last a while!  :)
Current
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2226555
Do you think that this build can work with the white version of the case? I really like the white more than red, to me it looks cleaner :o
Yes...? There's no difference between cases with different colors aside from the color differences itself. At least, there shouldn't because if there is, then that would be stupid if a red case has more drive cages while the white case has more fan mounts.
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2227438
I meant the coloring of the components, like will it work as well as if it was the red and black case because most of the components are red and black
Then I'm not the person to ask. As long as it's not puke green, neon pink, or shit brown, then I'll use whatever the hell I want and whatever works for me.
Anyway, you'd have a black/red interior with a white/black exterior. I don't think it would clash, but it would seem sort of "framed" since the case is an entirely different color.
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2227520
I dont think it would too bad. Im getting the black and white 760T with black and red insides scheme. All up to you really...
Current
https://linustechtips.com/topic/167291-i-need-help-with-a-build/#findComment-2227866
