Whats the point of fps capping in games, my monitor is only 60 hz so should i set my fps cap to 60 or 70? What does it do?
https://linustechtips.com/topic/167205-fps-cap-questions/
What will happens sometimes is if you are getting way higher fps than your refresh rate you will get screen tearing. If you arent someone thay even notices it then dont worry about limiting your fps or using vsync because doing so will usually cause input lag.
Sky Pollution | i5 3570k @4.8Ghz | MSi z77a g45 | MSi GTX 770 Gaming 2gb | Samsung 840 Evo 250gb, Samsung OEM 500gb HDD | Corsair CX750m | Corsair 760t White Edition |
Corsair M95 | SuperLux 668b's | Logitech C615 | ViewSonic VX2250wm | Random OEM keyboard until I rage break it and grab another random OEM keyboard from my pile.
Build Log: http://linustechtips.com/main/topic/186413-sky-pollution-my-white-760t-build-rebuildupgrade/
https://linustechtips.com/topic/167205-fps-cap-questions/#findComment-2224856
If you cap the monitor the GPU is not outputting anything more than, lets say, 60 fps. But if you don't cap it the graphics card is outputting a higher amount of frames that your monitor can handle, and that causes ''tearing''.
https://www.youtube.com/watch?v=Xl4nQfX0zoE
Case: Corsair Carbdie 330R Motherboard: Gigabyte GA-970A-DS3P Asus Z97-A CPU: AMD FX-6300 i5 4690K 3.5 GHZ + 212 EVO GPU: ASUS GTX 760 DirectCUII Ram: Corsair Vengeance LP 8gb (2x4gb) HDD: Seagate Barracuda 1TB PSU: Corsair CX500M
Monitor: AOC Q2963pm 29'' 21:9 IPS Mouse: Mionix Naos 8200 Mousepad: Mionix Sargas 320 Headset: HyperX Cloud Keyboard: Corsair Gaming K70 RGBIKEA Headset/Headphone Holder
https://linustechtips.com/topic/167205-fps-cap-questions/#findComment-2224866
Some console ports are capped to 30 fps because those idiotic and lazy developers thought it was a good idea to bind game physics to framerate, meaning that different framerates would break the game. Others do it with 60 to try and reduce tearing without vsync but it's not a great idea as people with 120hz monitors can't use them to their full potential. Don't bother with limiting framerates manually, it doesn't make sense.
sudo chmod -R 000 /*
https://linustechtips.com/topic/167205-fps-cap-questions/#findComment-2224991
Basically I believe it helps with screen tearing. And also, it makes FPS more stable. If say you were playing a game with FPS capped at 60, it'll probably only ever sit at 60 and never really change. But if you have unlimited, it can jump from like 400 to like 40, it's really quite random and depends on your rig.
https://linustechtips.com/topic/167205-fps-cap-questions/#findComment-2227025
