So I need to figure out how to get this under or around $500. Everything that he needs is in the Parts List, Thanks
BTW, the PC is being used for light gaming
CPU: AMD Athlon X4 760K 3.8GHz Quad-Core Processor  ($84.73 @ OutletPC)
Motherboard: MSI A78M-E35 Micro ATX FM2+ Motherboard  ($56.00 @ Amazon)
Memory: Crucial Ballistix Sport 8GB (1 x 8GB) DDR3-1600 Memory  ($69.99 @ Micro Center)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ NCIX US)
Video Card: Asus Radeon R7 260X 2GB DirectCU II Video Card  ($139.99 @ Amazon)
Case: Cooler Master N400 ATX Mid Tower Case  ($57.99 @ Mwave)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($24.99 @ Newegg)
Monitor: Acer G236HLBbd 60Hz 23.0" Monitor  ($109.99 @ Newegg)
Mouse: Corsair Raptor M45 Wired Optical Mouse  ($54.99 @ Newegg)
Total: $653.66
Generated by PCPartPicker 2014-06-15 01:06 EDT-0400
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/166536-help-with-friends-pc-build/
You could always switch to an APU for light gaming. No way you will be able to get a monitor and current spec build under $500. You could get a worse case. Save some money and get the 750k instead of the 760k. Can your friend use a tv for a monitor? Get a really cheap mouse?
I should be studying.
Swap to a corsair 200R and see if he has a HDD lying around.
I have a 320GB HDD laying around but he has never done this. He said he wanted to get into gaming so I'm trying to help him, I do have a 500GB Green HDD that I will be getting rid of.
| F@H STATS |
I'd go for a cheaper mouse for now. That is a nice mouse but if you need to cut the price I would say thats a spot to do it.
Well by light I mean BF4 and COD
| F@H STATS |
Can't get much cheaper than that can you? He has an old PS2 Dell Mouse right now, I forget if its ball or laser
| F@H STATS |
Try this. You could give him you WD 500gb drive. Then he could get the gaming mouse.
PCPartPicker part list: http://pcpartpicker.com/p/TFV2bv
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($169.97 @ Amazon)
Motherboard: Asus A55BM-K Micro ATX FM2+ Motherboard  ($53.99 @ Mac Mall)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($71.10 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($52.92 @ Amazon)
Case: Rosewill Line-M MicroATX Mini Tower Case  ($41.35 @ Amazon)
Monitor: Dell S2240M 60Hz 21.5" Monitor  ($119.99 @ Micro Center)
Mouse: Logitech M100 Wired Optical Mouse  ($7.99 @ B&H)
Total: $517.31
Generated by PCPartPicker 2014-06-15 01:14 EDT-0400
better build below.
60$ over ok? I wouldn't go any lower than a 270 and an APU really isn't worth it.
CPU: AMD Athlon X4 750K 3.4GHz Quad-Core Processor  ($79.49 @ OutletPC)
Motherboard: Gigabyte GA-F2A55M-HD2 Micro ATX FM2 Motherboard  ($44.98 @ OutletPC)
Memory: Patriot Viper 3 8GB (1 x 8GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Video Card: PowerColor Radeon R9 270 2GB TurboDuo Video Card  ($129.99 @ Newegg)
Case: Zalman ZM-T1 MicroATX Mini Tower Case  ($24.99 @ NCIX US)
Mouse: Microsoft SideWinder X3 Wired Laser Mouse  ($9.98 @ Mac Mall)
Total: $561.31
Generated by PCPartPicker 2014-06-15 01:16 EDT-0400
Total: $561.31
This is a great build. He can stretch the extra $60. Tell him to work a little more and wait. It will be worth it. This will blow an APU or a 260x out of the water. You could give him your WD drive and that would bring it down to $500
Total: $653.66
For Gaming I would go dual channel memory also a cheaper mouse wouldn't hurt XFX has a 1GB version of the R7 260X for $110 which would save a little bit of money as well
current build and total cost   http://linustechtips.com/main/topic/150083-thrift-shop-build/
I apologize for my crappy English I'm American
except the PSU for that is under powered 500watts or more is recommended
...430 is plenty for an R9 270 dude. A GTX 780 is fine with a 500W PSU. 430 is plenty.
Yeah PCPartpicker says 339w. My 780 barely draws like 250w
| F@H STATS |
With that budget, there's going to be some serious cutbacks.
Motherboard: Gigabyte GA-F2A55M-S1 Micro ATX FM2+ Motherboard  ($39.38 @ Newegg)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Video Card: XFX Radeon R7 260X 1GB Core Edition Video Card  ($89.99 @ Newegg)
Case: Enermax ECA3310A-W ATX Mid Tower Case  ($29.99 @ Newegg)
Monitor: ViewSonic VA2249S 60Hz 21.5" Monitor  ($119.99 @ Newegg)
Mouse: Cobra cobra II Wired Optical Mouse  ($11.49 @ Amazon)
Total: $513.23
Generated by PCPartPicker 2014-06-15 01:25 EDT-0400
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
Total: $513.23
A 1gb card? I would stretch for the build with the R9 270. The guy needs at least a 2gb card.
Why does he need atleast a 2gb card? Battle field four only REQUIRES a card with 512mb of memory
I didn't notice the VRAM.
Video Card: Sapphire Radeon R7 260X 2GB Video Card  ($99.99 @ Newegg)
Total: $523.23
Generated by PCPartPicker 2014-06-15 01:30 EDT-0400
Games are using more and more VRam these days. A card with 2gb will outperform a 1gb plain and simple. There is a big difference between minimum required specs and recommended specs buddy.
Total: $561.31
how do you find bulds so good for so little
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
