It's really conplex. I opened it up and figured out how the rad+fans go in, but now I can't get the front ventilated part on. It's like the damn thing shrunk or I'm not doing it right. How do I fix it?
See the flexing?
Thanks.
https://linustechtips.com/topic/166414-caselabs-rad-mount/
have you tried forcing it? ^^
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/166414-caselabs-rad-mount/#findComment-2214885
The flex bay goes in first, everything then fits in as with other flex bay mounts. If you have any questions, contact Jim or Kevin.
So you put that in the case, then mount the rad? I tried that, but couldn't get it.
https://linustechtips.com/topic/166414-caselabs-rad-mount/#findComment-2215298
I am fairly sure that's the way, but I got all drop-in rad mounts on the top and sides so I can't confirm. If you need answers immediately, head over to the caselabs subforum on OCN or the caselabs owner's club thread.
https://linustechtips.com/topic/166414-caselabs-rad-mount/#findComment-2215315
