Here is my new build:
http://pcpartpicker.com/p/XnS6
I am debating going with 3x gtx680s or the AMD equivalent. If I want the option open for 4 way sli with more hard drives in the coming years I believe the 1000w should do me, or is that overkill and I would want to go for 850w?
I also have an old system which I am having diagnosed for a power issue cord issue. I might just resleave/recable the 24 pin if thats possible, or Buy a new supply for it. Here is the build.
Gigabyte GA-N680SLI-DQ6
Duo E6750 Conroe 2.66GHz
Segate Perp 320gb ST3320620AS
OCZ plat 512x2 OCZ2P8001GK
OCZ plat 1gigx2 OCZ2P800R22GK
Zalman 7900 CNPS9700 LED
GeForce GTX 650 Ti 1GB
I am looking to have this as a NAS/Bittorent box if I can. May add another Sata card to it for more drives, I know hard drives don't draw much power, but looking at 10 hard drives and a dvd burner with this. What size power supply should I get for this. The graphics card will probably stay or even be downgraded so thats not an issue.
https://linustechtips.com/topic/16624-how-much-power-do-i-need-2-different-systems/
You could even get away with a CX430 for the old system
CPU: Intel Core i5 2500K | Case: Bitfenix Prodigy | Motherboard: GA-H61N-USB3 | RAM: Corsair 8GB 1333 MHz Video CardEVGA GTX 660 Superclocked 2GB DDR5
Power Supply: Corsair CX 430 | SSD: Samsung 840 120GB | HDD: 2X Seagate Barracuda 500GB 7200rpm | Monitor Asus PB238Q & Asus PB278Q
Mouse: Lenovo N50 | Keyboard: Apple Pro Keyboard | Operating Systems: Hackintosh OS X 10.8.5 & Windows 8.1
Any solid 850w should do but if you're gonna go with 3 680's, you might as well get a 1000w if you can get one at a good price.
Something like the cx430 should be plenty
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026&Tpk=cx430&IsVirtualParent=1
