Okay , so sorry if i missed the right place for this post but! I'm new :) So. i don't want this post to be too long and ill just jump in! I'm banging my head trying to figure out if i should get the all in one water cooling solution the Cooler Master Seidon 120V, or if i should get a air-cooler, the Cooler Master Hyper 103 EVO Low Profile cooler and a extra Fan for my case for the sake of good airflow. At the moment im running with a stock CPU cooler , and i have 1 intake fan at the bottom-front of the case. My CPU while gaming will hover around 60-65 degrees Celcius, while my GPU hovers around 60-70 degrees Celcius. Now im thinking about getting the Seidon 120V and later on a extra case fan. but im not a 100% sure it will fit in my case, because of the small Mother Board(although its not impossible). Sorry for this long post but i don't want to make a mistake, looking forward to some info!  :) And last but not least. here is my rig.
Case: Cooler Master Chassis K380
MB: M5A78L-M LX3
CPU: AMD FX-6300 (At stock speed, not over clocked)
GPU: Asus R7 260X 1GDR5
RAM: Kingstone Hyper X Blu 1600mhz (1 stick of 4GB)
Seidon 120V : http://www.coolermaster.com/cooling/seidon/seidon-120v/
Hyper 103 EVO Low Profile : http://www.coolermaster.com/cooling/hyper-series/hyper-103/
And my Case : http://www.coolermaster.com/case/mid-tower-k-series/k380/
https://linustechtips.com/topic/166154-cooling-for-gaming/
the seidons links broken but there's no point in getting a fancy aio for such a meh mid range cpu
Specs
https://linustechtips.com/topic/166154-cooling-for-gaming/#findComment-2211308
MB: M5A78L-M LX3
So you put the stock fan on the bottom or do you have front and bottom 120's? In that case I'd have some 3 good 120mm fans for front, bottom and rear and a 212 EVO if it fits. Should get your CPU in the 45 - 50's.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/166154-cooling-for-gaming/#findComment-2211323
Yeah don't bother with the AIO, I used to have the 120m and it was useless, the 120v is pretty much the same just with some minor changes.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/166154-cooling-for-gaming/#findComment-2219293
