Hey, so for school I have to make a program and I honestly have no idea where to start with this one... I would post what code I have so far but I'm really not sure how to do this. If someone could help me out and show me where to start or how to do this I would really appreciate it.
Here's the question:
Write WriteKONG a program that will read a file of 6 student records called marks.txt, which you must create yourself as shown below. Each student record consists of a student number (7 digits), a subject (for example "math") and an integer mark.
An example of two records would look like this:
2134523
Math
47
75676881
English
98
Your task is to read the file and create two files, one called pass.txt and the other fail.txt. Both output files should contain only subject and mark.
Thanks, and I understand you don't just wanna give me the answer but if you could just help me get started that would be nice.
https://linustechtips.com/topic/166099-java-help/
This might help you in reading in file http://www.homeandlearn.co.uk/java/read_a_textfile_in_java.html
Do a loop that read each line of the text
Since you already know the order of the data (student number, subject and mark), you can use mod 2 to record the subject and mod 3 to record the mark. If it's < 50 ( assuming 50 is passing) put it in the fail.txt. If its >=50 write it in pass.txt. You can use a data structure temporarily such as linked list or 2d arrays to store the results for pass and fail. Read those 2 linked list or array whichever you prefer and write it in the text file. Hope it helps.
https://linustechtips.com/topic/166099-java-help/#findComment-2210755
TextIO.readFile("marks.txt"); //reads from the file
while (!TextIO.eof()){ //while not at end of the file
TextIO.getln(); //retrieves the next line of text
-do stuff-
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/166099-java-help/#findComment-2210764
  • 2 weeks later...
2134523
Math
47
75676881
English
98
So our raw data is thus *6:
2134523Math4775676881English98
I'm making the assumption that each data field (student number, subject & so fourth) are delimited by a return (a new line in the file). Also that we have a fixed 6 lines per record.
Our task is then to read this input file (parse it) and then to create two output files; one for passing marks and one for failing marks.
If I were to approach this myself I would have three file processors. One for parsing the input and two for writing the output. I would also create a POD for the input records BUT because this is so simple that may not be necessary. I would process the records as they are read in and not after the whole file has been parsed. This will likely show that you have thought about memory usage; i.e. we read a record, create our POD, make our decision based on the mark field and then write the output to the appropriate file.
The single biggest problem in communication is the illusion that it has taken place.
https://linustechtips.com/topic/166099-java-help/#findComment-2267408
