2 Way SLI 780
Go to solution Solved by Oshino Shinobu,
So I'll go with the RM850 You are sure that it is enough for 2 way sli
And If my System will need 900V And my power supply can deliver only 850 Will it Fry my pc parts?
Yep. I have two, more power hungry cards on a 860w PSU and they run just fine.
I'm buying a new pc and I want to be able to do 2 Way SLI And I Dont know how big the power supply should be enough With some head room of -+150V
the pc I'll be getting:
Intel Core i7 4770K 3.5Ghz 8MB L3 Cache s1150
Noctua NH-D14 CPU Cooler
Asus SABERTOOTH Z97 MARK 1
G.Skill Aegis 8GB DDR3 1600Mhz
Gigabyte GTX780 OC
Seagate 2TB Barracuda Sata III
Samsung 840 Pro Series MZ-7PD128BW 128GB SSD SATA III
LG DVD±RW GH24NS x24 Black SATA OEM
Corsair RM750 750W Gold Active PFC 12cm Fan PSU
Corsair Obsidian 550D Mid-Tower Case No PSU
Microsoft Windows 8.1 English 32Bit / 64Bit Retail
Noctua NF-F12 PWM 120mm Case Fan 1500RPM(x2)
How much power will this system take With 1 GTX780(WF3)
And how much with 2 GTX780(WF3)
If my PSU Can't handle the Voltages that my parts are needing will it frie tham like my system needs 800V but my psu Can handle only 750?
https://linustechtips.com/topic/165808-2-way-sli-780/
I would get the RM850 just to be safe
https://linustechtips.com/topic/165808-2-way-sli-780/#findComment-2206819
I Should go with the RM850 For 2 Way SLI Or for one card
How much headroom will I have?
Will I be able to over clock my CPU And GPU ?
If you only get 1 card then 750 is more than enough
if you plan to get 2 cards and OC then the 850 makes more sense
https://linustechtips.com/topic/165808-2-way-sli-780/#findComment-2206839
For a single card, 750w is overkill. For dual cards, 750w will do, but 850w is a better idea for future expansion and overclocking.
https://linustechtips.com/topic/165808-2-way-sli-780/#findComment-2206842
Gigabyte GTX780 OC
Since you want to be able to do 2 way SLI get the RM850.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/165808-2-way-sli-780/#findComment-2206858
https://linustechtips.com/topic/165808-2-way-sli-780/#findComment-2206877
Your system wont need 900 watts.. ever, and no it would not fry anything
https://linustechtips.com/topic/165808-2-way-sli-780/#findComment-2206889
https://linustechtips.com/topic/165808-2-way-sli-780/#findComment-2206899
With two way SLI you'll never need 900W.
https://linustechtips.com/topic/165808-2-way-sli-780/#findComment-2206910
Ok thx One last question How much headroom Will I have in 2 way GTX780?(100V?)
About 100 watts which gives room for extra drives/usb devices etc etc
Also you want to be running your PSU at about 80% for best efficiency
https://linustechtips.com/topic/165808-2-way-sli-780/#findComment-2206931
About 100W+  Remember that a system isn't always running at full load either.
Thx
https://linustechtips.com/topic/165808-2-way-sli-780/#findComment-2206941
A single 780 will use <250W at full load, an overclocked i7 4770k at full load will never use more than 150W (way less, actually), all the rest will probably be <50W. Even if you stressed everything to the max (which you will never do in real life) and overclocked you would still be fine with a 750W PSU. For real world usage it is totally fine.
https://linustechtips.com/topic/165808-2-way-sli-780/#findComment-2206949
