Case Modding Tool Help
Go to solution Solved by Enderman,
That is basically the same as a dremel except cheap made in china quality.
A dremel is the best tool for modding because you have a ton of attachment options for almost any case.
If you plan on doing more modding in the future I would suggest buying a real dremel that will last you a much longer time :)
If this is a one time thing, then it should do the job fine.
I want to do a custom window on my friends PC. His side panel is made of steel.
Would this tool work?
http://www.amazon.com/Black-Decker-RTX-6-3-Speed-Accessories/dp/B0001GUDRI/ref=cm_cr_pr_product_top
I guess a better question would be:
What tools do you guys use to modify steel PCs without blowing your budget?
Also, I noticed a guy in the reviews said he cut through a 1/2" steel pipe, so do you think I'll be able to get a clean cut?
https://linustechtips.com/topic/165634-case-modding-tool-help/
https://linustechtips.com/topic/165634-case-modding-tool-help/#findComment-2204666
I didn't know the name of the tool. Looks like I'm buying a dremel! :D
http://www.amazon.com/Dremel-4000-6-50-120-Volt-Variable-Speed/dp/B002L3RUW0/ref=sr_sp-atf_title_1_2?ie=UTF8&qid=1402632116&sr=8-2&keywords=dremel
https://linustechtips.com/topic/165634-case-modding-tool-help/#findComment-2204672
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/165634-case-modding-tool-help/#findComment-2204679
Yup much better quality :)
Its like $100 more expensive, but totally worth it for DIY type guys!
https://linustechtips.com/topic/165634-case-modding-tool-help/#findComment-2204685
Here is a thread that is comparing the black & decker rtx-6 vs a dremel http://forums.gideontech.com/index.php/topic,31003.0.html
Also here is a product reveiw of the black & decker rtx-6
From what i have read, it can use all the dremal bits and accessories and it's very well built just like the dremal is.
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
https://linustechtips.com/topic/165634-case-modding-tool-help/#findComment-2204834
Black and Decker is a very respected company, and they make quality products. Just throwing this out there.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/165634-case-modding-tool-help/#findComment-2226934
