 hi guys
budget $250
I'm looking to get a new Mechanical KB i'm not sure on what to get i have heavy large hands and i have been using a G19 for the past 4 years and i like that but i think it's time to upgrade
 i like the ability to change the back light color on the fly and i'm not sure on what KB to get  as well as the multi-media keys and the G keys what are my options??
https://linustechtips.com/topic/165633-mechanical-help-p/
Corsair RGB K95 will be the last keyboard you will ever need to buy.
https://linustechtips.com/topic/165633-mechanical-help-p/#findComment-2204675
 hi guys
budget $250
In the coming months, July - September, Corsair is coming out with its new RGB line of Mechanical Keyboards, they have everything that you are looking for in a keyboard, and at less than $200.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/165633-mechanical-help-p/#findComment-2204966
Corsair RGB K70 :)
[spoiler=pc specs:]cpu: i5-4670k | mobo: z87-pro | cpu cooler: h100i | ram: 8gb vengeance pro | gpu: gtx770 ftw 4gb | case: nzxt switch 810 matte black | storage: 240gb ssd; 1tb hdd | psu: 750w corsair rm |
keyboards: max nighthawk x8 mx brown + blue led; corsair k60 mx red; ducky shine 3 tkl mx blue + orange led | mouse: deathadder black edition | audio: FiiO E10; sennheiser hd558; grado sr80i; sony mdr-nc200d; blue snowball |
https://linustechtips.com/topic/165633-mechanical-help-p/#findComment-2204989
 my other  question is : is it possible to remove the switches them selfs???   Eg. say i want to make my W.A.S.D keys feel really heavy or to be louder. is that a possibility ?
I saw something in the Anand K70 review that looked like the ability to replace the WASD keys with plain / colored ones.
Ease of replacement probably depends on the actual implementation of Cherry MX that the manufacturer decided to use. I have a feeling that regardless of manufacturing, Corsair probably won't take it back if you've messed with swapping the switches.
I would probably just buy the model with switches you like; it's a goddamn $150 keyboard. That's not cheap.
https://linustechtips.com/topic/165633-mechanical-help-p/#findComment-2210186
