How Do You Actually Install LED Strips?
Woody
So in my new 750D, I have white led strips just to show off the inside. Problem is, they always keep falling off from the top. I tried using double sided velcro but even that didn't stick enough. The led strips never want to stick either. How can I actually stick these damn guys to the top and sides without them peeling themselves off... is there a product that is recommended? These are just strips I got from my work at Micro Center.
huuum, Superglu ?!!
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
Bitfenix Alchemy LED strips are pretty much the only LED strips I'd recommend. It's taken just under a year for the sticky side of these to start wearing off, and they're still not falling off! :)
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
I use 3M poster mounts (pretty much double sided sticky foam). It's been years and my LEDs / SSDs haven't moved. They also have the benefit of not leaving residue when you remove them.
I concur with 3M mounting tape. Use it for all of my LED mounting, be it home accent lighting, computer lighting, etc.
Never really thought about 3m mount tape. Thanks for the idea!
 CPU: Intel i5-4690K  COOLER: XSPC Raystorm 750 EX240 w/ Ice Dragon White Nanofluid MOBO: MSI Z97 GAMING 5   RAM: G.Skill Sniper 8gb 2X4gb 2133   PSU: Corsair GS800  GPU: SLI MSI TWIN FROZR GTX 760 4GB CASE: Phanteks Enthoo Luxe    STORAGE: SAMSUNG 840 EVO 128GB, WD BLACK 1TB, WD GREEN 1TB, SEAGATE BARRACUDA 1TB, WD BLUE 320GB KEYBOARD: Ducky Zero DK2108S MOUSE: Logitech G600
I use mounting tape. 3M namely.
muh specs
Gaming and HTPC (reparations)- ASUS 1080, MSI X99A SLI Plus, 5820k- 4.5GHz @ 1.25v, asetek based 360mm AIO, RM 1000x, 16GB memory, 750D with front USB 2.0 replaced with 3.0  ports, 2 250GB 850 EVOs in Raid 0 (why not, only has games on it), some hard drives
Screens- Acer preditor XB241H (1080p, 144Hz Gsync), LG 1080p ultrawide, (all mounted) directly wired to TV in other room
Stuff- k70 with reds, steel series rival, g13, full desk covering mouse mat
All parts black
Workstation(desk)- 3770k, 970 reference, 16GB of some crucial memory, a motherboard of some kind I don't remember, Micomsoft SC-512N1-L/DVI, CM Storm Trooper (It's got a handle, can you handle that?), 240mm Asetek based AIO, Crucial M550 256GB (upgrade soon), some hard drives, disc drives, and hot swap bays
Screens- 3  ASUS VN248H-P IPS 1080p screens mounted on a stand, some old tv on the wall above it.
Stuff- Epicgear defiant (solderless swappable switches), g600, moutned mic and other stuff.
Laptop docking area- 2 1440p korean monitors mounted, one AHVA matte, one samsung PLS gloss (very annoying, yes). Trashy Razer blackwidow chroma...I mean like the J key doesn't click anymore. I got a model M i use on it to, but its time for a new keyboard. Some edgy Utechsmart mouse similar to g600. Hooked to laptop dock for both of my dell precision laptops. (not only docking area)
Shelf- i7-2600 non-k (has vt-d), 380t, some ASUS sandy itx board, intel quad nic. Currently hosts shared files, setting up as pfsense box in VM. Also acts as spare gaming PC with a 580 or whatever someone brings. Hooked into laptop dock area via usb switch
Hot glue works brilliantly, the 3m backing on the strips I get usually gives out after 12 or so months.
I have double sided paper tape and double sided foam. The paper tape is awesome, you stick it on and peel the paper off and you're left with the glue.
