System:
MB:MSI GD-80
GPU: MSI 660TI PE
RAM: 16 GB DDR3 Vengeance 1600
CPU: Intel i-5 3570k @ Stock clocks
Hyper evo 212
1920x1080
Lately every game i have played; I've noticed a drop in frames, and this has been going on for a week, or so. Recently it has made my games playable.
An example would be Watch Dogs; i was running it fine since lauch, but in the last week i've lost half on my performance; it was at 45-60 FPS, but now i'm running a solid 30, and dips down to 19; this is unplayable. All the settings are the same, as i remember them from optimizing it.
War thunder was running really good at 50-60 FPS, but now runs at 29 FPS
Same with every other game i play.
I'm also having a audio issue; the first 10 seconds of any audio feed that's not a game, is really scratchy, and distorted; it's kinda like a loud screech depending on the audio.
When i look at temps; all is well, but i noticed my "Core Voltage" (which i don't touch, as i do not over clock)  has nothing on it, and is grayed out..
Anyone got an idea
I destroy my enemies when I make them my friends.
~Abraham Lincoln
In times when we are on the brink of destruction, war, and loosing ourselves, let's remember a basic fundamental element of love, forgiveness, and understanding; God bless!
https://linustechtips.com/topic/164776-system-is-bugging-out-welp/
System:
MB:MSI GD-80
GPU: MSI 660TI PE
Hyper evo 212
1920x1080
Anyone got an idea
other than the CPU temps
what was the temps from the GPU?
can you use HWMonitor to verify?
see if you can replicate the problem again and watch all the temps
if you have afterburner installed, remove the program
make sure your are running the latest nVidia drivers
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
GPU is 75-80 on a heavy load.
Running latest drivers
I do, and the temps are normal :D
I'll try uninstalling after burner in second, and report back
~Abraham Lincoln
Check if your GPU is boosting correctly. If it's overclocked, back it up to the original settings and try again. Check the VRAM usage as well. If you notice spikes above 2GB than, that can explain your problems.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
