PCPartPicker have yet to update the list
the Z87 SaberTooth is similar to the Z97 variant you might need to refer to the product page of NZXT and Asus instead
or in doubt just email NZXT and Asus directly about compability
http://www.nzxt.com/product/detail/38-havik-140-cpu-cooler
The biggest question is... It's quite a big CPU Cooler... Is it gonna fit inside the Corsair Air 540 with all the components? I mean like, it says that it's compatible but who knows if it still is with all the components installed inside... It also says that it's discontinued?
uh bad news
it has been discontinued
so it means no longer for sale and no after sale support for that product
time to look for another model?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
uh bad news
Yeah, I just saw that... Basically the only one that I know that's white/black is the Evo 212... Do you know any other durable and quality CPU Cooler that's white/black?
It would already give me an easier task if I had a motherboard to select on PcPartPicker to see what is compatible or not...
i can only think of Noctua NH-D15 but I think you will not like it. Red fan blades
about the case modding you can ask the nearest case modders in your area in here
http://linustechtips.com/main/forum/21-cases-and-power-supplies/
fellow members will be able to direct you to reputable case modders in Canada
Only know that comes to my mind as well is the Evo 212  :mellow:
I could look deeper into it but I need a motherboard to base myself of from...
Let's forget the Sabranco for a little bit...
What's your opinion on these boards? http://pcpartpicker.com/parts/motherboard/?compatible_with=corsair-case-cc9011048ww#R=5,4&C=6,12,14,20,21,46&sort=d6&f=2&qq=1&s=24
Which is the best one in there in your opinion?
About the case modeling I will look more into that later on :) Right now I need to focus on a base build to have an idea of what I could build in the future.
if you ask me
http://pcpartpicker.com/part/asrock-motherboard-z87extreme6
the Asrock model looks fine
but you should consider a Z97 board
if you ask me
There's no Z97 of the colors that I chose... Well, damn...
There's only http://pcpartpicker.com/part/asus-motherboard-z97a but even then that's brown...
If I want a white one it's either gonna have to be one of those that are in the list that I gave you or I'll have to wait for Sabranco...
since you are not in a hurry to build this system
it best to wait for better parts which are coming along like the Haswell Refresh 4790k which will cost the same or slightly higher than the current 4770K and that Sabranco and by that time you will be able to get ready the casing painted and ready to just install the mobo.
Yeah... I was already planning on waiting for them but you know, like... I want something to base myself off from otherwise I'll just get confused in the future...
How does PC Case painting work exactly? Like, if I want to get it done by someone else?
usually the modders will take apart the whole casing and spray each part with a prime coat which is act as a base
than they will start with the shades of white and followed by the patterns of different color and then they re-build the casing
it quite similar to how ppl re-paint their car, they will take apart the body panels for repainting
Yeah, I know that... What I mean is how are they gonna paint it? Is there certain retailers or what? I live in Ottawa, so... Not really sure how I'm supposed to get it painted...
well i see
this i am not really sure but you can post a question in the Case and Power Supplies sub-forum section
some forums user from Ottawa might give you the answers
cheers
