not really it has been tested before by one user here with the 760s one was 4GB the other was 2GB, both cards were detected but the SLi option was not avaliable
I see, i was under the impression it would work.  :lol:
thanks for the insight
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
What do you guys suggest then? One 780 Ti or two 770 SLi? ( Even tho, I don't even know how SLi works )
Also, here's a list of motherboards that have the colors that I'm looking for:  http://pcpartpicker.com/parts/motherboard/?compatible_with=corsair-case-cc9011048ww#R=5,4&C=6,12,14,20,21,46&sort=d5&f=2&qq=1&s=24
I'm just not sure which one is best in 2014.
if you have the budget, sell your 770 and get a 780ti.
Do you mind linking me the Galaxy HOF? 780 Ti is more than fine... I will be adding a 700 Series in the future (770 or under)
Its damn expensive
http://ca.pcpartpicker.com/part/galaxy-video-card-78xnh5dv8pxv
CPU: Intel Core i5 4460 | GPU: XFX r9 280x DD BLACK OC EDITION | RAM: 8gb Kingston HyperX Fury 1600Mhz | Mobo: Gigabyte h97n-WIFI | PSU: EVGA 600B | Case: Cooler Master Elite 120 | Cooler: Stock intel | SSD: Samsung 840 EVO 120gb | Storage: WD 150 gb
CPU: Intel Core i7 4710MQ | GPU: NVIDIA Geforce GTX 850M | RAM: 8gb Corsair 1600Mhz | Mobo: Metabox WA50SJ Motherboard | Case: Metabox WA50SJ case | Cooler: Stock | SSD: Sandisk 256gb
:wub:  :wub:  :wub:
Best purchase this year, bcuz forza
like bbq say go single 780Ti
its more than enough to drive one 1440P monitor
here was the tread where the 760 SLi mode failed with with one 2GB and 4GB
http://linustechtips.com/main/topic/136964-not-allowing-2-gtx-760s-to-work-in-sli/page-2
we did the swap the 2GB card as master and 4GB as slave GPU didn't help
thanks nVidia...
AMD X-Fire just works better
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Well, maximum budget has to be $2000 no matter what...
I already have a 770 and I do not have a 780 Ti . . .
I just don't know; does two 770 SLi exceed a 780 Ti? I would expect so with 4GB instead of 3GB but it consumes more so the question is, is 3 case fans and the fans from the GPU's and CPU enough?
Is 750 Watts PSU enough? Should I get 850 Watts PSU?
IT DOES WORK. STOP.
read my previous post and the link
thanks nVidia...
its $800 for a 780 version.. $300 more than the cheaper end.
Also, I'm pretty sure that the monitor I said I wanted to play with is actually 1080p and not 1440p, though.
Well, maximum budget has to pay $2000 no matter what...
I just don't know; does two 770 SLi exceed a 780 Ti? I would expect so with 4GB instead of 3GB but it consumes more so there question is, is 3 case fans and the fans from the GPU's enough?
if you really want to sli in the future, get the 850w otherwise 750 is more than enough for one 780ti
the 780ti won't have consistency issues and you have the option to sli if you really really need the power later on.
it's the better option considering your budget
well performance wise the GTX770 SLi will outperform the 780Ti but you will have teething issues with newer games which do not support SLi so you many only be able to run only single card
750 Watts is fine for two GTX770s you don't need 850Watts unless you are trying to do OC with dual 780Ti
I know but he asked for a link soooo. Its even more expensive than 780 ti in AUSTRALIA
Link: http://www.pccasegear.com/index.php?main_page=product_info&cPath=193_1577&products_id=27206
:wub:  :wub:  :wub:
CPU Cooler:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($32.50 @ DirectCanada)
Motherboard:  MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($165.96 @ DirectCanada)
Memory:  G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1600 Memory  ($118.48 @ Newegg Canada)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Drive  ($94.99 @ Canada Computers)
Video Card:  EVGA GeForce GTX 780 Ti 3GB Superclocked Video Card (2-Way SLI)  ($754.98 @ Newegg Canada)
Case:  Corsair Air 540 ATX Mid Tower Case  ($123.39 @ DirectCanada)
Total: $2663.63
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-06-08 21:33 EDT-0400)
ok with dual 780Ti you are pulling 700 watts at least without OC
with OC you will be looking at least 800+ watts
if i swapped them for GTX770 SLi its drawing 660 watts with OC you will need only 750Watts
I will still suggest sticking to one single 780Ti and then SLi later but get the 850 Watts PSU first
and with a powerful GPU you can invest on a better monitor
^ this but a slightly beefier cooler if you plan to push your 4770k otherwise the 212evo is fine
Total: $2663.63
IT DOES WORK. STOP.
Okay, gotcha... I will just use one GTX 780 Ti, then...
I will overclock but it's going to be a really small one because I'm not an expert... I barely know anything about it but I will be learning as much as I can... I don't want to fry my GPU under a year.
Coming back to the build itself...
http://ca.pcpartpicker.com/p/hxPVGX
I'm not too sure about the motherboard and the CPU Cooler yet...
I'm hesitating between those two CPU Coolers: Either CM Hyper 212 Evo or the NZXT HAVIK 140
Here's a list of motherboards that fit the colors that I'm looking for: http://pcpartpicker.com/parts/motherboard/?compatible_with=corsair-case-cc9011048ww#R=5,4&C=6,12,14,20,21,46&sort=d5&f=2&qq=1&s=24
I'm just not sure which one is the best to have in 2014.
the NZXT cooler looks badass
Asus got the Sabranco although it only coming soon note the word on the bottom of the mobo say White Tiger in chinese
you in a hurry to build this system?
Hahah, no! I'm totally not in a rush... I won't have the budget for several months (6months +)
I'm just learning about all of this stuff including building one and stuff right now...
I'm planning my future Gaming PC and I will save all the informations on USB Keys once I'm ready in the future... At that time, I will make changes according to what has came out recently and if anything could fit the Gaming rig that I'm looking for  :lol:
Man, that Sabranco looks f*cking fantastic! http://hexus.net/media/uploaded/2014/6/9055ade3-236f-45dd-bda6-3ca43e5703c0.jpg
I wish I had that exact same design. ( The case and everything )  :(
in that case If you choose the Sabranco, you won't regret it look at the picture of the mobo in my original post above
your build can be nickname White Tiger with that mobo since it got a chinese name at the bottom of the board armor
the casing is the Cosmos II but you can pain your Air 540 with tiger stripes or Snow warfare camo paint
Hahah, yeah... It's freaking sweet I have to agree... I wish I had that exact design... The case and everything. That's f*cking epic. I'm really jealous, lol. http://hexus.net/media/uploaded/2014/6/9055ade3-236f-45dd-bda6-3ca43e5703c0.jpg
I would have to get that case to fit the Sabranco, though...
Hahah, that's exactly the problem... I can't even paint a tree properly... I wish I could paint those stripes man... You don't even know  :(
Even if I tried to, with my OCD I'd just end up smashing everything around me. Hahahah !
I'd have to find someone to paint it for me.
yea best leave it to experts to paint casings
you should be able to find case modders fairly easily
and a head ups they don't accept jobs for cheap
Meh, for a case like that I don't expect an exagerated amount of money... I don't even know where to find one in the first place and how...
But anyway... I can't really complete my build now that you've shown me that, hahah. I need to pick a motherboard for future references... I need to find which CPU Cooler to take also...
I'm just curious if the NZXT HAVIK 140 will work with the Sabranco...
That's basically it so far: http://ca.pcpartpicker.com/p/VTRTzy
I need a motherboard and I'm also worried about the CPU Cooler, actually... 1200 RPM compared to 2000 RPM on many other white ones. It's also pretty damn costy.  :mellow:
speed is one factor to consider for coolers but how big is the fan is another factor
bigger fan can draw more air at lower speed vs a smaller fan which need higher speed to match the bigger unit
check if the air 540 can accept the NZXT unit
the Sabranco is similar to the SaberTooth Z97 mark 1, see if the NZXT is compatible with the board layout
http://ca.pcpartpicker.com/parts/motherboard/?compatible_with=nzxt-cpu-cooler-havik140#s=24&f=2&R=5,4&sort=d5&qq=1
I need to find a motherboard in there to go with the fan and my case but I don't know, to be honest... Your opinion?
PCPartPicker have yet to update the list
the Z87 SaberTooth is similar to the Z97 variant you might need to refer to the product page of NZXT and Asus instead
or in doubt just email NZXT and Asus directly about compability
