HELP!! IS MY GPU DYING?? :(
Turns out it was because of multiple factors:
- I was using a DP 1.4 cable
-Cable visibly looked like new, but after moving probably got bent or damaged a bit
- i was running 1440p @ 240hz @ 10bpc color fine for a while
So i guess the cable was at the edge of what it could handle.... it getting slightly damaged introduced the random millisecond artifacts along with the black screen ( signal loss)
Bought both a DP 1.4a and a hdmi 2.1a everything ran fine now.... except the occasional flicker..... after a bit i remembered i was running 10bpc.... lowered it back to 8 and ever since i was issue free.
For everyone with this freak issue that scared u ....... Just try a new DP or HDMI cable rated for ur needs...... sometimes the cable will look completely fine..... when it is the issue
