Coil Whine
Go to solution Solved by OddOod,
it's annoying but normal
Hello!
I built my PC in late 2024, but never really gamed much until recently. Today, I was playing Call of Duty, and I noticed coil whine coming from my GPU (4070 Super OC).
Messing around with things, I decided to run Furmark. Upon running Furmark, I get zero coil whine. But when I launch CoD and load into a game, the coil whine comes back.
Is this normal?
https://linustechtips.com/topic/1634411-coil-whine/
1 minute ago, gilrobsd said:
Hello!
Is this normal?
Coilwhine can happen in some games and not be as pronounced in other applications.
I would say thats completely normal and nothing to worry about.
https://linustechtips.com/topic/1634411-coil-whine/#findComment-16880299
My good ol' GTX 1080 had zero coil whine ever since I rescued it from an etherium mine somewhere in late 2018. Except one single place.
It screeches like a hellspawn specifically in the main menu of Postal 2.
So yeah, coil whine just happens, nothing to worry about. Some cards are just more prone to it but every single one can surprise you with a song of their people if it feels so.
B550 | R5 5600 | RX 9070 XT | Fedora KDE
https://linustechtips.com/topic/1634411-coil-whine/#findComment-16880306
Well it depends really. The general rule is that the higher your fps is the louder the coil whine will be, cod as multiplayer game probably is pushing 200+fps depending on your settings.
It's normal behaviour of electronics and GPU in general, if it's not very loud then just be happy with that. It can get reaaaly loud on some models and most manufacturers won't RMA coil whine unless it's reaaaaly bad. Hell i once tested Samsung monitor and it actually had some coil whine lmao
Anyways there's no fix for this really, i heard some people claim that undervolting lowered their coil whine, so if it's distracting you enough, you might want to try that, and it's always a few $ in your pocket due to lower power draw 🙂
Ryzen 7 9800X3D / Gigabyte X870E Aorus Pro Ice /  2x 16GB Lexar 6000Mhz CL32  / Palit RTX4080 Gaming Pro / Samsung 990 Pro 2TB  + Samsung 970 EVO Plus 2TB / MSI MPG A1000G PCIE5 /  Lian Li O11 Dynamic EVO XL White /10x CoolerMaster MF120 Halo White + Deepcool AK620 WH Digital / IIYAMA G-Master GB2770QSU-B5 /  Corsair K70 Rapidfire RGB + Logitech G502 Hero / Aim SC808 + Edifier R1280T
https://linustechtips.com/topic/1634411-coil-whine/#findComment-16880510
Thanks for the reassurance! I’m pushing about 180+ in CoD on ultra settings, so it makes sense! It threw me for a loop hearing the whine come and go as I push frames!
Anyways, thanks for the reply!
Plus Ultra!
https://linustechtips.com/topic/1634411-coil-whine/#findComment-16880958
