Thoughts on my build?
Go to solution Solved by whispous,
I think you've chosen well for your specific use case, but I would recommend picking some faster ram. 6000mt minimum.
CPU: AMD Ryzen 9 9950X3D
SSD: SAMSUNG SSD 512GB M.2 NVMe 4.0x4 write: 6000mb/s read:5600mb/s
RAM: XPG ADATA DDR5-5600 32GB (16x2)
GPU: GIGABYTE Radeon RX 6700 XT OC D6 12GB
Motherboard: ASUS B650
Cooler: ARTIC Liquid Freezer III PRO 240
Power: Segotep BN850W
Case: Fractal Design Pop Air Solid
Purpose:
First time pc builder here. The most important thing is the CPU because I run many simulations that's multi-threaded and extremely CPU intensive that needs many cores/threads. GPU isn't that important. I don't play heavy games except Stronghold Definitive Edition and watch YouTube in 4k. I also don't use that much storage so I've settled on a 512GB instead. I also don't care much for the aesthetics, just the raw performance. What I worry most is the cooling as I will be overclocking my CPU so I dunno if a ARTIC Liquid Freezer III PRO 240 will be sufficient.
I'd like to know your thoughts and opinions on this optimized custom build.
https://linustechtips.com/topic/1633650-thoughts-on-my-build/
Purpose:
Budget and country you are located?
https://linustechtips.com/topic/1633650-thoughts-on-my-build/#findComment-16875242
You could put a 280mm radiator in the front of the case or a big air cooler up to a height of 170 mm.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1633650-thoughts-on-my-build/#findComment-16875243
Then the question is why is there a x3d chip? Its more expensive and not faser than the regular 9950x for sim tasks normally. Usually a bit slower.
Also @Why_Me 's got a good question as its hard to evaluate it without that info.
Also what are the prices on the parts? A 6700xt is old is this used?
https://linustechtips.com/topic/1633650-thoughts-on-my-build/#findComment-16875245
Korea. 2,500,000won or USD1700.
I want the fastest CPU for my CPU intensive multi-threaded simulations. New 6700 XT
https://linustechtips.com/topic/1633650-thoughts-on-my-build/#findComment-16875269
