My first desktop build
10 minutes ago, Maxinatr said:Budget (including currency): 40.000 CZK
Country: Czech Republic
Games, programs or workloads that it will be used for: Games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I’m currently using an HP Workstation laptop that’s about 10 years old, so this will be my first desktop build.
Here are components I’m planning to buy:
Motherboard: Gigabyte B650 AORUS ELITE AX V2CPU: AMD Ryzen 5 9600X
Ram: Crucial PRO Oc Gaming 32GB 6400MHz (with current prices might wait a bit)
GPU: ASUS PRIME GeForce RTX 5060 Ti 016G
Storage: Samsung 990 EVO Plus 2TB
Power Supply: Corsair RM850e
Case: NZXT H5 FLow Non RGB
CPU Cooler: NZXT Kraken 240 Non RGB
As for monitors, I plan to buy a main monitor with at least a 165 Hz refresh rate and 1440p resolution (most likely a 27" Samsung Odyssey G5 G53F). I haven’t decided on the second monitor yet.
Looking for thoughts tips on the build.
Look for a board that supports PCIe 5.0 for that graphics card that supports PCIe 5.0.
https://allegro.cz/obchod/czc-cz/nabidky?string=AMD Ryzen 5 7500F
AMD Ryzen 5 7500F
CPU Cooler: *be quiet! Pure Rock Pro 3 59.6 CFM CPU Cooler (1229.00Kč @ Alza)
Motherboard: *MSI PRO B850-P WIFI ATX AM5 Motherboard (3999.00Kč @ Alza)
Case: *Montech AIR 903 BASE ATX Mid Tower Case (1429.00Kč @ Alza)
Total: 6657.00Kč
Generated by PCPartPicker 2025-12-14 21:09 CET+0100
