Hey, so I'm planning on buying a pc this week for heavy gaming.
Here are the specs:
I7 4770k
Z97 sabertooth mark1
H100i
GTX 780ti DCU2 asus
Caviar green 1TB
2x intel 530 SSD both 180gb
Adata xpg 2133 16gb
H440 case.
And can you please pick it from here: http://en.ksp.co.il/?select=.1108..140.&store=KSP03
That's where I'm buying the pc
https://linustechtips.com/topic/162734-help-me-pick-a-psu/
EVGA 750g2, overkill, but nice
https://linustechtips.com/topic/162734-help-me-pick-a-psu/#findComment-2165891
Do you really need to buy from that site?
http://en.ksp.co.il/?uin=21582
Specs are on my profile page
 Teach a man to fish and he ends up sticking a screw driver in a turned on power supply seeing if it still works.        #KilledMyWifeWithABomb            Resolution is just a number
https://linustechtips.com/topic/162734-help-me-pick-a-psu/#findComment-2165970
Up to 550 on the store currency
http://en.ksp.co.il/?uin=21583
If you need modular:
http://en.ksp.co.il/?uin=17674
can also be considered
http://en.ksp.co.il/?uin=17395
Sec I thought you had a 780, not 780TI
these would be good options
http://en.ksp.co.il/?uin=15063
http://en.ksp.co.il/?uin=16196
Error: 410
https://linustechtips.com/topic/162734-help-me-pick-a-psu/#findComment-2165996
550 will do for sure?
https://linustechtips.com/topic/162734-help-me-pick-a-psu/#findComment-2166022
It will work, but the fan will spin up a bit during load.
Some of the 600w+ ones I suggested would be better as they should run cooler and quieter.
Which one of the three should i take? All are in my budget
I'd probably go with this one http://en.ksp.co.il/?uin=15063
If you care a lot about efficiency, the Antec one might be better, but not really by much.
Error: 410
https://linustechtips.com/topic/162734-help-me-pick-a-psu/#findComment-2166041
The difference between Bronze and Gold rated isn't huge. If the op isn't bothered about modular cables then the S12G would be the better option.
If the Seasonic S12G is in stock or you are able to find them,that should be your first choice. If not, the M12 is a good option although is only bronze rated.
I would go for the Seasonic M12 http://en.ksp.co.il/?uin=15063
How is the corsair cs650m for gaming? Its both modular and gold
https://linustechtips.com/topic/162734-help-me-pick-a-psu/#findComment-2170051
It'll work just fine. But not as good as the Seasonic unit,even if it is gold rated compared to Seasonic M12 bronze rated. I'd still take the M12 or S12 for your budget.
https://linustechtips.com/topic/162734-help-me-pick-a-psu/#findComment-2170226
It is not as good as the Seasonic S12/M12. It will run your pc perfectly fine, but it is a step below quality wise as it uses a manufacturer called Great Wall who are not as good as Seasonic.
 I see, how will i benifit from a modular PSU? and do i really need it? if not i think ill go with the s12G
https://linustechtips.com/topic/162734-help-me-pick-a-psu/#findComment-2170264
Californication, on 08 Jun 2014 - 01:14 AM, said:Californication, on 08 Jun 2014 - 01:14 AM, said:
You don't really need the modularity if you have space in your case. Modular psu will be better for cable management especially in a tight or small windowed case where internal aesthetic is your priority. But there are ways to properly tuck all of the unused cables if you take some time to arrange them. You can ask for help here if you need one. Don't let the non-modular aspect be a hindrance in getting a good psu and settling for lesser unit.
https://linustechtips.com/topic/162734-help-me-pick-a-psu/#findComment-2170340
