What do you guysbthink is the best move here do you think selling my R9-290 Tri x then buy a 780ti is good move? note I only play on 1080p monitor atm... heres my build
CPU: i5-4670
Mobo: Ga H87n
Ram: 2x4gb Gskill
Case: Prodigy
PSU: 850watt seasonic X series 80+ gold
do you guys think its a good move? or what do you thunk i should sell. and replace?
thanks for the time reading
https://linustechtips.com/topic/162670-help-please-confused/
nahh its just because of watch dogs and ive been seeing better fps on nvidia side maybe thats why ive been think on changing my gpu.. do you think changing my processor will do any good?
It'll be fine, I'm sure.
Give it 3 months and then they'll probably end up performing the same or incredibly similarly
Compatible with Windows 95
https://linustechtips.com/topic/162670-help-please-confused/#findComment-2165150
still any suggestions
... You're playing 1080p with a 290. I don't really care WHAT game you want to play, 60FPS should be really easy.
[spoiler = "My Computer Stuff"]
My ITX:
240 Air ; Z87I-Deluxe ; 4770K ; H100i ; G1 GTX 980TI ; Vengeance Pro 2400MHz (2x8GB) ; 3x 840 EVO (250GB) ; 2x WD Red Pro (4TB) ; RM650 ; 3x Dell U2414H ; G710+ ; G700s ; O2 + ODAC + Q701 ; Yamaha HTR-3066 + 5.1 Pioneer.
Things I Need To Get Off My Shelf:
250D ; 380T ; 800D ; C70 ; i7 920 ; i5 4670K ; Maximus Hero VI ; G.Skill 2133MHz (4x4GB) ; Crucial 2133MHz (2x4GB) ; Patriot 1600MHz (4x4GB) ; HX750 ; CX650M ; 2x WD Red (3TB) ; 5x 840 EVO (250GB) ; H60H100iH100i ; H100i ; VS247H-P ; K70 Reds ; K70 Blues ; K70 RGB Browns ; HD650.
https://linustechtips.com/topic/162670-help-please-confused/#findComment-2167157
why don't you ask these questions to yourself? is the cpu letting you down? is the gpu letting you down? it all matters on how you think it performs.
My Little Gaming Rig:
CPU: FX 8320 | MOBO: Gigabyte 970A-D3P | RAM: G.Skill Ares 2x4GB | GPU: Sapphire Dual-X R9 270X | Storage: Seagate SSHD 1TB | Case: Corsair 200R | PSU: CM 550W V-Series
Upgrades to come: CPU FAN: Corsair H100i | RAM: 2 more 4GB sticks | GPU: Another R9 270X running in crossfire | Storage: Samsung 120GB SSD | PSU: Corsair 800w
https://linustechtips.com/topic/162670-help-please-confused/#findComment-2167159
If it's Watch_Dogs we're talking about, then no wodner.
Watch_Dogs is so STUPIDLY badly optimized it's unbearable for AMD. It works better for Nvidia, not because Nvidia cards are better, but because that game is AIMED TOWARDS Nvidia more. And I mean a lot more.
Could probably just wait and see if they fix Watch_Dogs. It's just a badly optimized game, it's not anywhere near being AMD's fault.
https://linustechtips.com/topic/162670-help-please-confused/#findComment-2167570
