You may want to change your title to get more views and probably interactions. Many people wouldn't read this because they would probably think you found a giant piece of dirt.
On note of that picture- I'm not really sure. Have you tried contacting your manufacturer? Its perhaps your mobo dosen't support it so its not connected, but thats quite the intresting find!
thanks for the suggestion man, we'll see now hehehe. Oh and no I haven't but ot's because acer are such d!cks and they don't want you to do anything to your laptop so they won't tell you anything :(
Dell XPS 15 9560 - Nikon Z5 - Galaxy S10+
Wouldn't that just be because you can put a second antenna put your laptop model doesn't?
That wireless card only has Wifi on it, no bluetooth (from what I can find with the model number anyway...)
oh right thank you very much, that actually makes sense. just  question, how did you research for it? I mean i typed in every number I saw on it and it clearly didn't work hahaha :P
First searched for t77h194.10
Which gave me
https://wikidevi.com/wiki/Foxconn_T77H194.10
Which then led me to to chip used, which is BCM4313, that led me to
http://www.broadcom.com/products/Wireless-LAN/802.11-Wireless-LAN-Solutions/BCM4313
Which gave me
alright thanks!!!
