Hello, I have a WD Blue 1TB HDD and it's a bit loud and I'm crazy about silence. Since I moved to an SSD the hard drive is going to idle after like 15 minutes, if I want to access it it starts again, I really like it but could I improve it? Is it possible to do something that the HDD goes idle after like a minute to five? BIOS change maybe?
https://linustechtips.com/topic/162247-control-over-hdd-going-idle/
i dont think so.
"Change power-saving settings" in windows.
Search "Power" in your start menu.
Click on "change plan settings"  and click "change advanced power settings"
Then click hard disk, and then "turn off hard disk after"
Yes i think there was someting like this on Windows ^^
