not for minecraft but for dayz you would need either a 660 or 750ti at minimum but to play with nice frames and such a r9 270(x) or gtx 760
Specs
https://linustechtips.com/topic/162001-minecraft-and-dayz/#findComment-2156512
I was looking at the r7 265 would that work?
Yes, that would be fine.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/162001-minecraft-and-dayz/#findComment-2156541
probs but try to get a gtx 660 there much better and around $200
No it isn't.. The 265 trades blows if not simply outperforms the 660 when both oc'ed.
https://linustechtips.com/topic/162001-minecraft-and-dayz/#findComment-2157537
