Hey guys, when i try to install windows i get stuck at the "searching for disks" part. It stays there for a while and after gives me this error. My SSD is seen in BIOS and when i open terminal during win installation i can see both the SSD and the USB flash-drive that i use. I made the USB twice, once with rufus and the second time from "the windows installation media maker". Both time i have the same issue.
https://linustechtips.com/topic/1619970-memory-problems-during-installation/
3 minutes ago, Jaeger_bg said:
that was one of my concers as this disk is brand new so idk how it is, same goes for the USB
Sorry, it 's not full, just there are partitions you didn't list.
In diskpart:
sel disk 0
list part
And show what partitions are there, perhaps it's more informative.
Also one of the things to try - reseat RAM.
Pax vobiscum
In diskpart:
sel disk 0
list part
i'll check the RAM
https://www.thewindowsclub.com/windows-error-code-0x80070017
Seems to suggest it's most likely a problem with the ISO image or the USB installation drive... if you have a different USB flash drive try that, then if still no luck, redownload the image would be my suggestion.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
I think the Google AI has some interesting things to say about the error code - "0x80070017" "0x4002f" :
https://www.google.com/search?num=10&sca_esv=261d4272bff7f900&rlz=1C1CHBF_enEE1136EE1136&sxsrf=AE3TifN2hfb8sErtl0pvItCt5ynRlqrhog:1754752439999&q="0x80070017"+"0x4002f"&sa=X&ved=2ahUKEwjPk-uegv6OAxX1MhAIHSMaLUoQ5t4CegQISBAB&biw=2560&bih=1271&dpr=1
Quite a few different possible problems to troubleshoot.
Pax vobiscum
