My First PC Build: Phantom
temmerich
Not really a build log, just sharing my finished build.
This is my first PC Build, which I completed a few weeks ago.
Components:
NZXT Phantom White Case
Asus P8Z68-V PRO/GEN 3 Motherboard
Corsair Vengenance Blue Low Profile Ram 16GB (2x8GB) with plans to upgrade up to 32gb
Intel Core i7-3770K OCed to 4.4GHz
Cooler Master V6GT CPU Cooler
EVGA GeForce GTX 650 Ti Boost Superclocked 2GB GDDR5 Memory (with plans to add a second card in 2-way SLI)
OCZ Vertex 4 128GB SSD
Various HDD's used from other PC's for a total of 2.25TB's total storage
NZXT Hale90 850 Watt Modular Power Supply
DVD Burner
Various NZXT Blue LED case fans
Media Card Reader
5.25in Bay case boxes (2)
NZXT Hue RBG LED controller
Phantom Windowed Side Panel
Windows 7 Ultimate
Hope you guys enjoy it!
(Sorry for the so-so picture quality)
post-13371-0-39983400-1368500329_thumb.j
post-13371-0-28481100-1368500333_thumb.j
post-13371-0-24122300-1368500338_thumb.j
post-13371-0-67345000-1368500341_thumb.j
post-13371-0-46043200-1368500345_thumb.j
post-13371-0-15954100-1368500351_thumb.j
post-13371-0-57603400-1368500354_thumb.j
post-13371-0-39504400-1368500411_thumb.j
Looks good, there are so many phantom builds lately.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
Thanks, and yeah I've noticed that, I've had the case since December and seen lots of Phantom builds since. Its a great case for the price
nice build, you have managed to keep it quite tidy :D
P.S I love bacon too B)
Cable Mgmt. is my thing lol. And who doesn't?!
there is nothing worse than a build where they didn't bother on the cable mgmt front  :wacko:
Tell me about it, why bother building your own if you aren't going to keep it tidy? Might as well buy an OEM machine *cringe*
Agree :D
I must have used like a hundred cable ties on my current build :blink:
Finishing ATM B)
Yeah that sounds about right for mine too lol, what;s your part list?
Awesome build but why so many HDD's?
Thanks! And because I have a ton of parts laying around from my work so to cut costs I used used HDD's and an ODD
Oh ok nice.
Why do you need 32GB Memory? and a i7 3770k with a Cooler Master V6GT CPU Cooler? That is amazing does it overheat? I have 16GB memory at 1600MHz and can do CAD work along with some light video editing.
Computer: CPU: Intel i7 3770k 4.2 GHz, Processor Cooling: Corsair 100i,  Video Card: ASUS Geforce GTX 660ti, Motherboard: ASUS P8Z77 V PRO, Power Supply: corsiar AX750, Hard Drive: Toshiba 2TB, Case Fans: Bitfenix Specter x 2, Case: Phantom
I don't, 16 is enough, I just want to max out the RAM capacity. and at 100% burn I never went over 70C even with my 4.4GHz OC, its a good cooler.
Wow, Thats pretty awesome cooler if your stable at 4.4. Cool build!!!
How did you fit an 8 pin through the 8 pin cutout? I tried but I could never get mine to fit.
Thanks! I was pleasantly surprised to reach 4.4 stable. Was getting unstable going at 4.5 an beyond, hopefully I can get it higher when I upgrade to a water cooling loop
It was not easy lol, I had to have a friend help me hold the mobo while I fed the 8 pin through without the mobo screwed it, then screwed it in after the cable was already fed through
I don't know what they were thinking not making that hole larger. I always forgot to plug it in before I put the motherboard in.
The empty space around everything looks really good, also really tidy. I think you need more hard drives though  ^_^
Me either lol my biggest complaint about the case. I still love it though, especially with my windowed side panel
Thanks, that what I was going. I'm all out of drive bays and sata ports -_-
looks good.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
