1 hour ago, TheAtomicSoul said:
Anyone able to recommend a complete front IO Panel with USB-C for a DIY PC case?
(Edited- it posted while I typed the title.)
https://lian-li.com/product-tag/i-o-ports/
I don't think it's an often enough occurence (buying a complete front I/O) that people can recommend with confidence which one is atleast up to spec.
But atleast Lian Li is very well known brand
Refresh before you reply
Several case manufacturers offer i/o front panel replacement parts.
For example https://www.phanteks.store/collections/replacement-parts/products/evolv-x-replacement-parts?variant=39488095060023
I can't recommend any one in particular, but if you want one that fit's in a 3.5 or 5.25 inch bay, there are lots available.
https://www.amazon.com/s?k=front+io+for+pc+usb+c&crid=23YYZBH0BKWS1&sprefix=front+io+for+pc+usb+c%2Caps%2C160&ref=nb_sb_noss
go by the reviews and price.
I'm also interested in this. So far I discovered most of the I/O bay panels are made in China and sold with a markup.
If I search all those you can find on Amazon by image, I find them on aliexpress at less than half the price. For example
https://vi.aliexpress.com/item/1005008196019717.html
It's about 15 bucks in my currency. But if I look for retailers in my country, it costs more like 40 bucks. ^^
That one in the link has ok USB-C specs and has 2 dedicated connectors (19pins for regular USB and the type E one that is only for USB-C connectors on the mobo).
Can't vouch for the quality though. I think I'll take this one next month.
