2 minutes ago, 3022619145 said:
Hello can anyone tell me how can I optimize my Intergrated GPU
Intel Pentium Gold G5420 3.80Hz
INTEL UHD 610
Make sure the RAM is the fastest your CPU/motherboard supports, and make sure the RAM is two sticks. Also make sure your CPU/iGPU isn't overheating. Make sure all system drivers are up to date (CPU, GPU, motherboard BIOS).
https://linustechtips.com/topic/1615682-help-optimization/#findComment-16752076
2 minutes ago, KidKid said:
Make sure the RAM is the fastest your CPU/motherboard supports, and also make sure your CPU/iGPU isn't overheating. Make sure all system drivers are up to date (CPU, GPU, motherboard BIOS).
Im running a 2400MHz DDR4 Ram. Plus idont know how to update my Bios or the cpu
https://linustechtips.com/topic/1615682-help-optimization/#findComment-16752077
For what? Watching youtube? this thing can't game. Even minecraft is asking too much. This would be considered a slow computer for word.
Any oc won't even give you a single fps. You can't do anything here to get more gaming performance. If it's struggling in youtube playback. yeah same thing cpu is super weak with about as low end a integrated gpu you can get in the last 7 years. There is nothing to do here.
https://linustechtips.com/topic/1615682-help-optimization/#findComment-16752087
You've got a dual core Coffee Lake CPU with fairly low-end integrated graphics. Sorry to say it but your computer's not going to be a gaming powerhouse unless you upgrade your hardware. You're not going to "optimize" any significant gains, or see a reasonable frame rate unless you exclusively play games from 25 years ago.
What motherboard do you have? (Or if you have an OEM-built PC, what's the model number?)
https://linustechtips.com/topic/1615682-help-optimization/#findComment-16752089
How many sticks of RAM?  Keep in mind this CPU iGPU will never become a beast.
https://linustechtips.com/topic/1615682-help-optimization/#findComment-16752095
INTEL UHD 610
Nothing short of asking for a dedicated GPU is going to make any difference.  Everything people above are suggesting will amount to nothing at all for an iGPU of that level of CPU.
You've got a basic computer, nothing wrong with it, just it is what it is.
Can you talk to your folks about it and possible upgrades?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1615682-help-optimization/#findComment-16752099
INTEL UHD 610
Change it 😁
https://linustechtips.com/topic/1615682-help-optimization/#findComment-16752102
Lacks details. Knowing these lower end CPUs are more common in laptops and other pre-builts means you probably don't have much options to do tweaking. If you have normal mobo with full control, things you can do is to increase VRAM size. This requires that you have 8 gigs or more RAM. Preferably 16gigs so you can dedicate 3-6 gigs of that for iGPU. Overclocking is nope, or not in meaningful ways. And if we are talking about pre-built, power supply most likely wouldn't like it either.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1615682-help-optimization/#findComment-16752458
MSI H310M PRO PLUS
MSI H310M PRO PLUS
https://linustechtips.com/topic/1615682-help-optimization/#findComment-16752462
25 minutes ago, 3022619145 said:
MSI H310M PRO PLUS
Your motherboard is compatible with Intel 9th gen CPUs.
https://www.msi.com/Motherboard/H310M-PRO-VDH-PLUS/support#cpu
You're going to have to upgrade your CPU, and ideally your GPU along with it, if you want that computer to game well. Like I said, an i5 would be fine if you can get one for a good price.
What power supply do you have? (We need to know this in order to recommend appropriate GPUs. A low end power supply limits what kind of GPUs you can install without upgrading that as well.)
https://linustechtips.com/topic/1615682-help-optimization/#findComment-16752481
1 hour ago, 3022619145 said:
MSI H310M PRO PLUS
MSI H310M PRO PLUS
Just post your full specs. Easier to give advice when we know what you are working with. Better if you have budget/markets for upgrades. But as said, best you can do is make sure you have enough RAM assigned to iGPU. Nothing much you can do with locked CPU and iGPU which doesn't have anything you can tweak besides how much RAM is used as VRAM.
https://linustechtips.com/topic/1615682-help-optimization/#findComment-16752508
