Power Supply Concern for GPU
Go to solution Solved by PDifolco,
1 hour ago, Alien_47 said:
No im saying if I manage to buy a 500W with a 8 pin will it run fine?
Or should i do something else
That's ok
Think about getting more than 500W, you can find decent 650W PSU for not much
So, I have a STOCK Dell Optiplex 7010 the tower one (i'll attach a picture)
I am now finding the need to buy a GPU, specifically the RX 5500 XT
Now can I use this graphic card with the stock power supply?
I will upgrade the system's power supply but not now.
So can i run and use the RX 5500 XT without a power supply for like a month.
If i use this GPU without a PSU, then will it damage the GPU in anyway?
Or should i get the GTX 1060.....(and will 1060 work?)
https://linustechtips.com/topic/1613282-power-supply-concern-for-gpu/
There are tons of different 7010 versions out there, so without knowing the exact model nobody can know. Best is to open yours and check the PSU ratings and what cables are available.
F@H
GPD Win 2
Hmmm, the 7010MT might actually use a standard ATX PSU...
13 minutes ago, Alien_47 said:
I really dont know much about PSUs and wattage things....
Take a pic of the PSU and we can tell you what the wattage is
You shouldn't be able to damage the GPU by installing it. But not sure what you mean "without PSU". If the GPU has power connectors, it likely won't boot without being powered.
You should know that even if this is a top spec 7010, it will only have, at best, a 4790K which is a pretty weak CPU
18 minutes ago, Alien_47 said:
So this was really the reason i posted in this forum........
Open the panel and look at the PSU, wattage and cables, you need a PCie 8pin cable to power any decent GPU
Also has this thing a standard ATX mobo or some Dell Boardenstein monstrosity ?
I have these specs:
Stock MBD
i5 3470
275W max PSU (no extra cables available) but i can upgrade now to a 500W
8gb ddr3
GT 710
1 minute ago, Alien_47 said:
I have these specs:
Stock MBD
i5 3470
8gb ddr3
GT 710
Thanks
That's a very old PC (13 years) and a mid range one at that. Before we really go any deeper into it (you're gonna need either a different GPU or a different PSU so we're talking about spending money), what are you planning on using this for?
3 minutes ago, OddOod said:
Thanks
normal gaming like no hesi (assetto corsa), fh4, ac origins, valo, spiderman miles morales, etc. and a bit of Ae
SO i can upgrade the PSU to a 500W one and what graphic card will be best under 115$ in the used market
Okay, those are games where you'll be in the neighborhood of "minimum requirements", but be aware that the min-reqs can mean that the game will run at 10FPS all settings low.
Looks like the best GPU would be the 1070ti but you'll have to snipe a deal and be wary of scams.
And 500W is a pretty skimpy PSU these days. Is this an old unit you have laying around or one you're buying new?
so at the plaace where i live, i can easily get a 5500 xt 8gb under 110-115$
and that is a pretty good gpu
and a 500w psu is easily available under 25$
You'll need to source an adapter as well because those things don't use standard PSU connectors on the mobo.
F@H
GPD Win 2
The OptiPlex unlikely uses a normal ATX PSU.
AMD 7950x3D / Gigabyte Aurous Master X670E/ 64GB @ 6000c30 / 3 x 4TB Samsung 990 Pro / 44TB Synology 1522+ / MSI Gaming Trio 4090 / EVGA G6 1000w /Thermaltake View71 / LG C1 48in OLED + MSI 321URX - Moved back to air cooling Phantom Spirit 120 SE.  Server (PLEX) - 155H NUC 64GB  and 60GB Optane drive/ Server (AI) 64GB M4 Max Mac Studio
Im sorry but i didnt understand that, can you explain a bit
Pls post pics of your mobo where we can see how it's plugged to the PSU
If it ain't standard ATX 24pin you cannot upgrade the PSU to an ATX one
These are the pictures of the mobo see if I can do anything to it regarding The PSU and the GPU
Ok, it really needs some cleaning but connectors looks like standard and you can upgrade the PSU !
Yeah its been a while since i cleaned it.
So if i upgrade the PSU and GPU to 500W and RX5500 XT 8gb, will it run fine or do i buy some other GPU. (will it cause any issues etc.)
TBH 275W is fine for that machine and a 5500XT but using adapters is kind of dicey if you don't have an 8pin I wouldn't bother.   Looked up the model on the PSU does at least appear to be ATX.
That's ok
From everything I've seen online, this is one of the last models that Dell *didn't* use a proprietary PSU
