Hello! I just built my first computer, everything works great except of the GPU. Even though it spins the fans and the Nvidia driver installer identifies it, it won’t give any video signal. I even disabled IG but now I get no display at all.
CPU: Ryzen 7 7700X
GPU: GIGABYTE RTX 5070
EDIT: The second I posted this, it worked 😭
https://linustechtips.com/topic/1612928-gpu-won%E2%80%99t-post/
CPU: Ryzen 7 7700X
To get the integrated graphics back, remove the CMOS battery ( silver battery on the motherboard ) for 5 minutes.
Put it back in.
This will reset the BIOS and you will at least get your display back from the onboard graphics.
https://linustechtips.com/topic/1612928-gpu-won%E2%80%99t-post/#findComment-16734590
So when the display cable is plugged into the GPU it doesn't display but you get display when plugged into the motherboards display ports?
You'll need to reset the CMOS in order to get the iGPU working again.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1612928-gpu-won%E2%80%99t-post/#findComment-16734591
Put it back in.
That’s great to know, it just posted though 😂
https://linustechtips.com/topic/1612928-gpu-won%E2%80%99t-post/#findComment-16734592
Sweet!
Enjoy 🙂
I would still have the iGPU disabled as it can conflict with the Nvidia GPU in some games or programs.
I have had to disable the iGPU on both my 7700x and 9800X3D, I use an RTX 4080.
https://linustechtips.com/topic/1612928-gpu-won%E2%80%99t-post/#findComment-16734595
Put it back in.
Hey! I am getting another issue that I didn't test yesterday. GPU works fine on windows but then I try to boot into the BIOS, I get no display. I know that I am in the BIOS because of the "boot" light on the motherboard. Motherboard: MSI X670e gaming plus wifi, CPU: Ryzen 7 7700x, GPU: Gigabye RTX 5070
https://linustechtips.com/topic/1612928-gpu-won%E2%80%99t-post/#findComment-16734896
I would try to update the BIOS through the BIOS Flashback method and go from there.
Did you also remove the CMOS so that you get the iGPU back or did you skip this yesterday?
https://linustechtips.com/topic/1612928-gpu-won%E2%80%99t-post/#findComment-16734898
4 minutes ago, AIRPIEGAMING said:
I can't remove the CMOS battery, it takes WAY too much force to do it, I am scared to try using more force
Of course you can, its removable on all motherboards.
Did you flip the latch holding it in place?
It shouldn't require uncomfortable amount of force to do.
https://linustechtips.com/topic/1612928-gpu-won%E2%80%99t-post/#findComment-16734914
If you want to add me on Discord we can communicate quicker?
You can of course delete me afterwards.
My Discord is Hinjima
https://linustechtips.com/topic/1612928-gpu-won%E2%80%99t-post/#findComment-16734915
