well thats the problem im trying to save the most amount of money for the best cooling performance... sorry that i ddnt state that.
Go for a high end air cooler instead they are cheaper than the h100i, perform the same but are much quieter.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/161229-over-clock-temp-help/#findComment-2146220
NH-D14 /15 performs similarly to an h100i. I had an h100i and the cooling was great, but everything else is nothing but trouble. The pump starts making weird noises after a while, the stock fans are crap and need to be replaced, adding extra cost, and the LED logo tends to break.
https://linustechtips.com/topic/161229-over-clock-temp-help/#findComment-2146252
like a noctua
yeah U14s, D14, D15. darkrock pro 3 or PHTC14PE
https://linustechtips.com/topic/161229-over-clock-temp-help/#findComment-2146345
