From what I've heard is that the 3 pin wall to PSU plug is standardised so any legit fits, it's the cables after the PSU that are unique. I'd just get a wall plug. I've just bought one for my Corsair PSU that came with UK plug to EU but yet to test it.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
Just get the proper mains cable. The plug that goes in the power supply is called IEC C13
As it's a 1000w psu, at maximum wattage it will pull around 5-6A from mains, so you should look for a cable rated for at least 10A  (AWG 18 or AWG 16 thick wires).
With UK plug : https://www.amazon.co.uk/PRO-ELEC-HP-B13-2ALVB-C10-Lead-Black/dp/B07FGGC5ZH/
With EU plug : https://www.amazon.co.uk/PremiumCord-KPSP2-power-cable-coupler/dp/B00AOAJAUC/
If you're in UK, try cpc.farnell.com  , it's a sort of uk only / reduced inventory / free or cheaper shipping version of Farnell com
IEC C13 power cables  :  long link to cpc.farnell.com with some filters pre-applied
