Budget (including currency): £2500 initially with £500 credit (idly not using any credit)
Country: UK
Games, programs or workloads that it will be used for:
Other details
Mostly building an SIM games with lots of moods.
Right so I'm paying around with some configurations of a system on ether overlockers pcspelsists or cyberpower there prices and availability make it a sensible choice for me combine with my own ability.
I would like to have a nice 1440p experience and was looking at having something the centers around the rx9070xt.
I'm just stuck on way CPU to go for
How much should i be spending on a motherboard.
Is having 4 sticks of ram really that bad shout I just get 64 now if I can
https://linustechtips.com/topic/1608009-motherboard-and-cpu/
Country: UK
Other details
PCPartPicker Part List
CPU: AMD Ryzen 5 9600X 3.9 GHz 6-Core Processor  (£209.99 @ Ebuyer)
CPU Cooler: Thermalright Phantom Spirit 66.17 CFM CPU Cooler  (£37.00 @ Computer Orbit)
Motherboard: Gigabyte B850 GAMING WIFI6 ATX AM5 Motherboard  (£161.99 @ CCL Computers)
Memory: Corsair Vengeance 64 GB (4 x 16 GB) DDR5-5600 CL36 Memory  (£203.86 @ Amazon UK)
Storage: Western Digital WD_Black SN850X 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£77.00 @ Amazon UK)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£98.00 @ Amazon UK)
Video Card: Zotac GAMING AMP Extreme INFINITY GeForce RTX 5080 16 GB Video Card  (£1159.99 @ AWD-IT)
Case: NZXT H7 Flow (2022) ATX Mid Tower Case  (£79.00 @ Computer Orbit)
Power Supply: be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£108.69 @ NeoComputers)
Case Fan: Noctua P14s redux-900 49.26 CFM 140 mm Fan  (£15.95 @ Amazon UK)
Monitor: Asus ROG Strix XG27ACG 27.0" 2560 x 1440 180 Hz Monitor  (£538.57 @ Amazon UK)
Total: £2690.04
Generated by PCPartPicker 2025-04-06 15:04 BST+0100
*using non-conversational, sketch-level language to gesture at structure and direction.
The GB8/12 Liberation Front
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699914
8 core AM 5Ryzen unless you heavily multitask or something, 8 cores should be plenty for games
less than 200 pounds on motherboard
yes having 4 sticks is not good, 32GB should be enough, if you never fill 32GB now, you won't fill 32GB later, you can always add the 2 extra sticks later
15 minutes ago, Timme said:
Total: £2690.04
over budget (nor not I guess)
slow-ish RAM with 4 sticks instead of 2
Country: UK
Other details
CPU: *AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  (£259.99 @ Amazon UK)
CPU Cooler: *Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  (£29.99 @ Overclockers.co.uk)
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (£149.00 @ Computer Orbit)
Memory: *TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£91.99 @ Overclockers.co.uk)
Storage: *Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£98.00 @ Amazon UK)
Video Card: *XFX Quicksilver Radeon RX 9070 XT 16 GB Video Card  (£676.96 @ Ebuyer)
Case: *Montech AIR 903 MAX ATX Mid Tower Case  (£59.99 @ Overclockers.co.uk)
Power Supply: *Thermalright TG 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (£99.00 @ Computer Orbit)
Total: £1464.92
Generated by PCPartPicker 2025-04-06 15:19 BST+0100
current PC:
PC configs I used before:
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699916
16 minutes ago, podkall said:
over budget
Includes a monitor and an extra case fan.
It's a dual-channel mb and AM5 isn't AM4, the speed is plenty for the CPU and GPU, and completely removes the need for the Windows page file forever and ever.
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699922
It can be whatever channel MB, AM5 isn't AM4, you are right.
AM4 is actually fine with 4 sticks, but AM5 isn't.
Because DDR4 is older than DDR5, DDR4 has been figured out, DDR5 is still too recent. And AM5 isn't just guaranteed to work with 4 sticks on OC.
current PC:
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699925
It works fine under 6000MHz on good motherboards.
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699928
But you don't want under 6000Mhz. You want to be gaming, being under 6000Mhz is not gaming, that's 2:1 fabric-clock ratio, potential stuters, or overall slowness because the average latency is lower:
current PC:
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699931
Again, it is plenty for the CPU and the intended tasks. CL30 is for the top-tier HW and much more complex tasks. 3 nanoseconds in gaming is nothing.
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699933
You'd be surprised, also this is top-tier, you are paying 2000pounds for a PC.
current PC:
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699940
1 minute ago, podkall said:
You'd be surprised, also this is top-tier, you are paying 2000pounds【907,18 kg】 for a PC.
I'm talking 500$+ CPUs.
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699942
9800x3D costs less than 500$, there's a reason people go for specific speed and timings, it's not "fine" to just go little bit less, not for everyone.
current PC:
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699950
And the GPU was 5090? Or 4090? With 5080 those will be the same at 1440p.
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699953
@james8449834 here's a board that supports PCIe 5.0 seeing how these RX 90XX gpu's support PCIe 5.0. Plenty of RAM for your mods.
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (£362.39 @ Amazon UK)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  (£29.99 @ Amazon UK)
Motherboard: *MSI B850 GAMING PLUS WIFI ATX AM5 Motherboard  (£176.39 @ Ebuyer)
Memory: *Patriot Venom 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory  (£159.99 @ Amazon UK)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£88.99 @ Amazon UK)
Video Card: *Gigabyte GAMING OC Radeon RX 9070 XT 16 GB Video Card  (£699.99 @ Ebuyer)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  (£49.99 @ Overclockers.co.uk)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£99.99 @ Amazon UK)
Total: £1667.72
Generated by PCPartPicker 2025-04-06 16:29 BST+0100
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
Monitor: *AOC Q27G4X 27.0" 2560 x 1440 180 Hz Monitor  (£159.00 @ Amazon UK)
Total: £159.00
Generated by PCPartPicker 2025-04-06 16:32 BST+0100
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16699954
They're not same at 1440p
current PC:
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16700010
Think again.
We are talking about RAM latency, what does this have to do with anything?
current PC:
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16700020
Because RAM latency is only good if the GPU can match that latency.
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16700026
No? Do you buy 5400RPM HDD when you don't have high-end PC because "it doesn't affect load times the PC is not fastest of the fastest anyway"?
GPU doesn't even communicate with RAM, like what are these arguments?
current PC:
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16700050
The GPU (specifically, the GPU command processor) will then read the buffers from system memory, and start executing the commands.
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16700052
current PC:
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16700054
Required assets and cache for visual enhancement calculations.
If VRAM is for cache, what's GPU's cache for? How long do you want to be on this hill?
current PC:
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16700065
Ufff, I've talked about video card ram overall. Fine with you?
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16700068
Okay, so this is the second time I have to remind you, we were talking about RAM latency, and now you completely moved all goal posts, so I think I'm done here...
current PC:
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16700072
I'm sorry, wasn't your point that the GPU doesn't interact with system RAM? Idk why you asked about VRAM.
https://linustechtips.com/topic/1608009-motherboard-and-cpu/#findComment-16700082
