Fiio E10, AKG K612 Pro
Is the Fiio E10 (which I own) enough to drive the AKG K612 headphones to sufficient levels without distortion (clipping)? In his review of the E10, nwavguy suggests a minimum sensitivity of 106 dB/V. The K612 are 101 dB/V which from my understanding is pretty low.
I do not listen to music at live levels and most of my library is classica. Are there other headphones I should consider? I'm looking for fairly neutral, open cans with good soundstage and decent bass extension. The K612 seem to have all of these qualities and for less than $200. If the Fiio is likely to be "good enough" I'm willing to add and O2 later if it would make a significant difference, but I'm not spending $350+ all at once on audio.
My Syba DAC is good nuff, so the E10 should be fine as well.
Don't get an amp for headphones under 350$ is my way of thinking, unless the headphones have crazy impedance.
after you reach the 350$ point you should start looking into amplifiers.
Plz no.
