is my cooler enough?
Go to solution Solved by PDifolco,
Yup, it'll be ok for a 100W TDP CPU, don't worry if the CPU still gets very hot on full load, it's due to the 3D cache thing that blocks heat dissipation, whatever the cooler
In gaming you should hover around 65C
https://linustechtips.com/topic/1607281-is-my-cooler-enough/#findComment-16694858
Yeah on average that should probably be true, just Ryzen spike like crazy, it's not a bad thing but people could get spooked when they see 75 or 84c, etc...
-Scott Manley, 2021
https://linustechtips.com/topic/1607281-is-my-cooler-enough/#findComment-16695914
Indeed, especially with aircoolers !
https://linustechtips.com/topic/1607281-is-my-cooler-enough/#findComment-16696034
thank you
https://linustechtips.com/topic/1607281-is-my-cooler-enough/#findComment-16697644
