Cat6 cable properly done?
Solved by Omon_Ra,
On 4/3/2025 at 11:16 AM, DSD27 said:I don't know... What I know is that the connector is shorter and larger. My other ethernet cables have a thinner and longer plastic head.
Hard to tell from your pics, but it looks like those might be pass-through ends. You can tell by looking 'head on' at the end, where the wires inside the connector end. If you can see/touch the bare copper/insulation sticking out, it's a pass-through. If it's fully 'sealed' plastic, it's a non-pass-through. I almost always use pass-through's (EZ's) these days, but I have noticed certain RJ45 sockets don't like them for whatever reason. It's this nubbin that seems to cause issues.
