I am making the switch to wired and need to cut rectangles for the ethernet boxes. My walls are plaster and i need help finding a way to cut through it!
I want it to look clean and not crack or whatever...
Thanks for your help!
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
https://linustechtips.com/topic/160582-how-to-cut-through-plaster/
I used a hole saw (Below)
But i need a rectangle for the gang box.....
Current
For ethernet wall plug a box is not necessary to be installed like an electrical plug you use a wall bracket that holds onto the back of the drywall giving screw points for the ethernet jack wall plate to screw into once the correct sized hole is cut.
thats what i was meaning, forgot the name of it
Current
I just need to cut the rectangle out for that wall bracket... and some basic instructions please
Current
Couldn't you just use hollow wall boxes which use multiple circles like these?
PICTURES
This would make it a lot easier and cleaner looking.
Friend from the US, please don't take this personal.
The circle installation boxes are used in europe. But from my own experiences I can say that the US power installation are far behind what we have in Europe, or what is standard in Germany. The US is such a developed country, so I can't understand why they still stick to their old ways of power installation. I got shocked by a power socket in the US, while touching the two metal pins as I was trying to plug something in behind the couch. The power didn't turn off. If I would do the same thing at my house, I would probably be safe.
Also the most newer house in europe use Wago, which is a safer way of connecting wires.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
Here this video is pretty straight forward:
1) measure and cut the hole
2) Install the bracket for the wallplate
3) Then thread the Ethernet cable through the now installed bracket
4) Connect the Ethernet cable to the Ethernet jack for the wallplate
5) Screw into place.
If you are running Ethernet through the walls for the first time, then I highly recommend using these instead of regular punch-down ethernet keystone jacks:
Cat6 RJ-45 Ethernet Keystone Coupler Jack
They're available in Cat5 as well but you may as well use cat6 (And it should work with gigabit either way). Basically with these, the cable you run through the wall is just plugged into one end of the jack, and then another cable is plugged into the second end.
You can still make your own bulk cable or you can buy pre-made runs/patch cable. Less hassle than the traditional punch-down jacks.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
i just need help on how to cut though the  plaster.
Current
Im not too sure if you guys are picking up what im laying down.... i know what materials to use to mount it, I just need help on how to cut the rectangle in through the plaster (not drywall) and lathe i think.
Current
Honestly you're much better off (learning wise) to either youtube a how-to video, or better yet, just go down to your local hardware store and ask. Do you have a Home Depot or whatever else is popular in the USA nearby? If so, just drop on by and tell them you need someone to show you how to cut a rectangle cutout in drywall for installing wall-plates. They'll walk you through the basics and show you which tools you need.
BASICALLY, the video posted by @W-L is exactly what you need. Trace the hole using a pen or a sharpie (marker), then cut along the lines. I would recommend using a drill in one of the corners of the trace (or all 4 corners) first though. Or even drill several holes side by side. This helps you get the drywall knife in at first and makes starting the cut easier. If you use a power saw, it'll be easier and faster, but just take it SUPER slow.
Oh ok I get at what your saying now since i thought you were refer plaster as to drywall.
But in that case if you have a oscillating Dremel tool it will work really well for this situation, if not you can carefully make a bunch of holes in the pattern of the bracket and carefully remove the plaster then slowly cut at the lathe on the back with a small hand saw, just be careful not to pull on the lathe while cutting to not make the surrounding plaster fall off. You can also go at it with a utility knife through the plaster to reach the lathe in the back but it may take some time epically if they layered the plaster on thick.
Edited by W-L
yes I have a home Depot, Ill go tomorrow and ask them. Thanks for the help
Current
