Retrocomputing question (Pentium 75mhz)
They were released on Socket 5 and Socket 7 : https://www.cpu-world.com/CPUs/Pentium/Intel-Pentium 75 - A80502-75.html
You can filter them by release year, socket or manufacturing process here : https://www.cpu-world.com/CPUs/Pentium/TYPE-Desktop Pentium.html
If you get the Socket 7 version then you would probably be able to upgrade to Intel pentium mmx maybe up to 233 mhz , AMD K5, K6 maybe even K6-2 - the later cpus would require "Super Socket 7"
CPU World should have a list of processors compatible with Socket 7.
But it really depends on what voltages the motherboard can provide to the cpu socket and supported FSB frequency - back then cpus needed two voltages, one for the core and one for IO ... could have something like 3.3v for the core and 2.8v for IO .. some motherboards didn't support some combinations and you couldn't use some cpus with them. Also some chipsets supported only up to 66 mhz fsb, but some chips ran on 75 mhz or even 100 mhz fsb
