The trick that always works for me:
Dont have so many cables.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Glue a power strip to the bottom of the desk. That way you don't need to have as many cables running to the outlet. Edit also you are using the cable management as a tray instead of a wire management system.
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
