Hi,
     I used AVG One Click Maintenance and it seemed to clean up and speed up my computer a tone. It runs about 20% faster which is crazy for a program. I use to clean my computer once a week myself now I just run the program. It Defrags you hard drive(s), Cleans your Registry, removes unused shortcuts, deletes browsing history and a ton more. What do you think of the program did it help you?
Computer: CPU: Intel i7 3770k 4.2 GHz, Processor Cooling: Corsair 100i,  Video Card: ASUS Geforce GTX 660ti, Motherboard: ASUS P8Z77 V PRO, Power Supply: corsiar AX750, Hard Drive: Toshiba 2TB, Case Fans: Bitfenix Specter x 2, Case: Phantom
https://linustechtips.com/topic/16017-avg-one-click-maintenance/
I shall test it now, not fond of their antivirus though.
CPU: i5 4430 PSU: XFX 550w Ram: 8gb Patriot Viper 1600mhz
Motherboard: MSI H87M-G43 Case: Fractal Design Define R4
SSD: 840 Evo 250gb, 512gb MX100 GPU: MSI GTX 980TI Gaming Cooler: Hyper 212 Evo
https://linustechtips.com/topic/16017-avg-one-click-maintenance/#findComment-181110
I have found there anti virus works best as a Firewall and not really an antivirus when you already have viruses on your system. When there already on your system I recommend Malwarebytes.
https://linustechtips.com/topic/16017-avg-one-click-maintenance/#findComment-181119
It is done now, apparently fixed a bunch of problems and did various other things. Need to restart for some improvements to work but I am going to see how things are later.
https://linustechtips.com/topic/16017-avg-one-click-maintenance/#findComment-181148
Cool hope it works as well as it did for me.
https://linustechtips.com/topic/16017-avg-one-click-maintenance/#findComment-181155
I did just notice it filled my metro UI with 25 new shortcuts
https://linustechtips.com/topic/16017-avg-one-click-maintenance/#findComment-181161
