Hey everyone, so I am running into a problem with my computer. I recently updated to windows 11 from windows 10, and now my 5900x at idle is 76-80 degrees on a lian li galahad 360 AIO. Before I upgraded my cpu was idling at 45-50 degrees on windows 10. I don’t have any overclock on my cpu. Everything is set to the default settings. The only overclock I did was the RAM to the 3600Mhz, which was also applied on windows 10. Is there some sort of settings or something I need to change in windows 11? It’s weird that the only thing I did was update to windows 11 and now my temperatures are crazy. Any help you guys can give me would be appreciated. Also I have an ASUS Crosshair hero viii motherboard.
https://linustechtips.com/topic/1600765-5900x-cooling-problems-after-update/
Is your pump running?
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
