First Ever AMD Build Advice
Go to solution Solved by Hinjima,
10 minutes ago, ChrisLoudon said:
Nice one buddy, that worked a treat.
Having been an Intel man for pretty much 3 decades makes all this a bit different but easy enough when you know what to look for.
That's 5.5Ghz on all cores maxing at 74c. Still need to look at my fan curves so can probably that down a few degrees more.
CPU package power topped out at 130w and R23 score of 24017.
Does that sound about right?
Perfect! 🙂
Yeah, I have been overclocking Intel CPU's for over 20 years but I bought a Ryzen 7700x in January 2023 so I had to learn how AM5 works.
And the 9800X3D works a little bit different with the Scalar options etc.
5.5Ghz is what I was expecting, this is what I am running as well.  Its a decent bump up from stock 5225-5300Mhz while being stable without overvolting or crazy temperatures.
74c during an all core load is great!
If it crashes during any gameplay or similar you should just change the -30 curve optimizer to -25 or -20. That should be enough, not all AM5 CPU's can handle -30.
Yup, that looks like a normal power / wattage draw at 100% load and the score looks great.
I see around 70-95w during CPU heavy games.
All looks good 🙂
I see no reason to push it further.  It will definitely affect stability and there is diminishing returns by bumping up the core speed.
Hi guys,
While I've been building and tinkering with PCs ever since the 286, I have never build at AMD based system until this morning when my PSU finally arrived.
I was just wondering if anyone had any BIOS / Windows setup advice?
Specs:
9800 X3D
MSI X870 Tomahawk Wifi
2 x 16GB Corsair Dominator DDR5 PC5-48000C30 6000Mhz
Antec HCG Pro 1200w PSU
GPU - using iGPU until I can get my hands on a 5090
Cooling - Dual Loop Custom Water
Case - Lian-Li o11 Evo XL
I've updated the BIOS to latest
Enabled EXPO Profile 1
Installed Win 11 Pro - no bloody ethernet or wireless drivers on install so that was a bit of a faff
Installed AMD chipset drivers
Installed AMD Adrenalin GPU drivers
Windows Updates done as usual
Everything seems to be working perfectly but since this is my first AMD I wasn't sure if I've missed anything.
I do have one 'unknown device' in device manager which I'm not sure about.
Idle temps are 42c and a couple of passes of Cinebench R23 which boosts all cores to about 5300Mhz peak at 72c. Room ambient is 22c.
Any other tips and tricks would be welcome.
C
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1600707-first-ever-amd-build-advice/
27 minutes ago, ChrisLoudon said:
Hi guys,
Specs:
9800 X3D
C
Everything looks good. Nice computer 🙂
What you can do is mess around with PBO and Curve Optimize.  This is basically an undervolt with an overclock.
I run my 9800X3D at 5.5ghz with similar temperatures to you.
Your temperatures look great both for idle and 5.3ghz all core boost though, fantastic.
I would also recommend uninstalling the Radeon Driver and disabling on iGPU in the BIOS once you get the 5090.
I had issues with my 7700x and 9800X3D where the iGPU would interfere with my RTX 4080 and some programs would read the Radeon graphics instead of my 4080.
I have helped at least 10 other people coming to the LTT Forum with an issue like this.
If you ever have to return the 5090 if it fails you can always reset the CMOS to get the iGPU back 🙂
Thanks buddy,
Good to know I've not made any massive mistakes.
With regards to PBO and Curve Optimizer, I was going to give Ryzen Master a whirl first given I'm not too sure about the BIOS settings but I can't get it to run. It installs ok but as soon as I try and run it, I get a 'Ryzen Master Unable to Initialize' error.
Any ideas?
Thanks buddy,
Any ideas?
Hmm, no idea. Never encountered that problem.  I don't use Ryzen Master.
Here are some fixes you can try.
The settings in the BIOS is actually very simple.
You just enable PBO and put a -30 on the Curve Optimizer and thats it.
It might not be stable at -30 so if it crashes you try -25 and keep going in 5 increments until stable.  The Curve Optimizer is the voltage.
I did PBO Enabled and -25 Curve Optimizer and I also manually added 200Mhz on all cores.
I always recommend doing anything like this in the BIOS and not through Software.
Even though Ryzen Master is a very good program.
Here you can see in the beginning how he enabled PBO and does a -30 Curve Optimizer on a Ryzen 7000 CPU on an MSI B650 motherboard.
The BIOS should be similar to yours and its the settings are the same for a Ryzen 9000.
Thanks for the link. I already tried those fixes but nothing seems to be working. From the looks of things RM is affecting a number of users.
As far as the BIOS tweaks go, I did as you suggested and set the CO to -30 and that made a huge difference to temps. Temps maxed at 60c @ 5.3Ghz.
I couldn't for the life of me find a BIOS setting to increase my core frequencies. There was an entry at 4700Mhz  but I couldn't edit that and I couldn't see anything anywhere with an editable 53, 54, 55.... multiplier bit.
Looks like I've got plenty of thermal headroom so would be handy to know how to get a few hundred more Mhz out of each core.
I am reading through the BIOS manual for the X870 Tomahawk to find the settings.
Under overclocking you should find
Precision Boost Overdrive Scalar Ctrl: Set this to Manual.
Precision Boost Overdrive Scalar: When set Ctrl to Manual, type in 10 here.  This is just a little bit of voltage boost if needed. Nothing that will harm your CPU or cause issues.
CPU Boost Clock Override: Enable.
Max CPU Boost Clock Override(+): Type in 200.  This is the max you can type here.  This will add a 200Mhz boost to all cores.
Here is a picture from my ASUS BIOS.
Yours will be a bit different but things should be named the same.
I watched a lot of guides for the 9800X3D overclocking and I found this to be the most stable and safe overclocking method.
I have been overclocking for 2 decades but the AM5 platform is a bit different with the PBO and Curve compared to old school overclocking.
You can push it to 5.7Ghz with some other tweaks but stability is not guaranteed at this speed.
I would say that a PBO, -30 to a -20 Curve optimizer and a +200 Mhz all core is the way to go for stability and reliability.
Perfect! 🙂
All looks good 🙂
